MUM Europe 2020
jerryroy1
RB112 and RB133 winbox disconnects?
Mon May 07, 2007 6:40 am
All,
Deploying a new Hotspot with a RB133. I keep getting disconnected when using winbox. When it does connect it is up for up to 5 minutes and is extremely slow showing any details such as license or IP’s inside of winbox before the disconnect. I upgraded to 2.9.42 and I still have the same issue. I swapped the RB133 for a RB112 and am having the exact same problems. I have my notebook computer plugged into the poe adapter and have statically set IP on both the RB and notebook. No matter what I try I get disconnected.
I started to suspect the POE adapter but changed it out and still have the same problem. Any other ideas?
cmacneill
Mon May 07, 2007 4:46 pm
What wireless cards are you using? Many people are reporting problems with high power cards requiring more current than the RBs are capable of supplying.
Regards
Chris Macneill
usrox
Wed May 09, 2007 12:31 pm
Hi, Run "sys reset" and reconfigure your routerboard :D it may solving your problems.
Users browsing this forum: Bing [Bot], Google [Bot] and 114 guests
