tonick2001
ipsec ikev2 Split Include do not send to windows 10
Thu Jan 16, 2020 2:00 pm
VPN VPN IKEv2. The connection is normal, but the routes do not come.
OS: Windows 10
The operating system of the router 6.46.1
emils
Re: ipsec ikev2 Split Include do not send to windows 10
Thu Jan 16, 2020 2:07 pm
Windows does not support split include. Instead DHCP options are used to work around the limitation. Check IPsec debug logs, you should see something like this immediately after the tunnel establishes:
14:06:04 ipsec,debug recv DHCP inform from 172.16.3.253
14:06:04 ipsec,debug,packet     secs = 600
14:06:04 ipsec,debug,packet     ciaddr = 172.16.3.253
14:06:04 ipsec,debug,packet     chaddr = 00:00:00:00:00:00
14:06:04 ipsec,debug,packet     Msg-Type = inform
14:06:04 ipsec,debug,packet     Client-Id = 00-AF-4E-C4-01-17-3E-F5-4A-86-EC-B2-2B-20-07-19-CE
14:06:04 ipsec,debug,packet     Host-Name = "DESKTOP-CVOOPP9"
14:06:04 ipsec,debug,packet     Class-Id = "MSFT 5.0"
14:06:04 ipsec,debug,packet     Parameter-List = Domain-Server,NETBIOS-Name-Server,Vendor-Specific,Subnet-Mask,MS-Classless-Route,
Domain-Name
14:06:04 ipsec,debug sending DHCP reply
14:06:04 ipsec,debug,packet     siaddr = 10.155.130.201
14:06:04 ipsec,debug,packet     Server-Id = 10.155.130.201
14:06:04 ipsec,debug,packet     Msg-Type = ack
14:06:04 ipsec,debug,packet     MS-Classless-Route = 192.168.1.0/24->10.155.130.201
Znevna
Thu Jan 16, 2020 5:01 pm
If your WAN Type is PPPoE on MikroTik this would not work, issue also described here:
viewtopic.php?f=2&t=154743&p=764979#p764979
And I also have (still) an open ticket regarding this, SUP-3815, support acknowledged an issue that fits my description.
I was hoping the fix would make it in 6.46.2 but looks like it didn't, based on the changelog.
tonick2001
Thu Jan 16, 2020 7:15 pm
Thank's. I will have to use Powershell
emils
Fri Jan 17, 2020 12:44 pm
Unfortunately, the issue appears to be caused by Fast Path driver for PPPoE which is why it takes a longer time to resolve it, however we are still working on it. You could try disabling Fast Path on your router (if that is an option for you of course) to see if starts working then.
tonick2001
Fri Jan 17, 2020 2:24 pm
Does it turn off here?
/ip settings set allow-fast-path=no
I tried, but nothing has changed.
emils
Fri Jan 17, 2020 2:33 pm
Did you reboot the router after setting it?
Znevna
Fri Jan 17, 2020 5:15 pm
I've tried, but I don't know how to disable FP for PPPoE.
I've set allow-fast-path=no in IP settings and in bridge settings (though it is not part of a bridge but I've disabled everythig that had fast path in it).
I've disabled the fasttracking FW rule.
Rebooted.
And I still see traffic in "FP Rx Rate" for the PPPoE interface. Traffic in FP Tx/Rx on the interface it sits on also visible (ethernet1), and on the other ethernet ports too.
(Have I found another issue? i'm damn lucky. lol).
Also still no DHCP Inform in the IPsec debug logs.
tonick2001
Mon Jan 20, 2020 7:09 am
Yes
Users browsing this forum: Bing [Bot], fredcom, sindy and 204 guests
