ros44
login failure only from Winbox
Tue Feb 11, 2020 11:24 am
Something super odd is happening to me.
The device is hAP ac2 running 6.46.2. My last successful login was 3 days ago. Since then I didn't do anything.
Now when I try to login via Winbox I am getting a login failure. I thought I messed up the credentials after trying a 100 times but I just decided to do a telnet test and boom!!! it worked with the same credentials.
Via telnet, I even added a new user with a new password and again it doesn't allow me to login via Winbox. I have a feeling this is a bug.
I don't have any filtering enabled for Winbox service.
Any ideas?
Every moment something magical is happening!
normis
Re: login failure only from Winbox
Tue Feb 11, 2020 11:59 am
Make sure you have the latest version of Winbox.
or ... are you copying and pasting the password maybe?
Dude2048
Tue Feb 11, 2020 12:05 pm
Had the same thing. I disabled via SSH the winbox ip service en enabled it again. That worked for me.
@Normis, Great photo!
Users browsing this forum: cruzo, pe1chl, topbanana, xvo and 46 guests
