jelwin
Best VPN
Thu Feb 13, 2020 3:49 pm
i need a vpn between 2 Offices, but only one office have a static ip adress behind a firewall.
the uplink and downlink is on the office 2 1mbit and 4mbit
wath is the best vpn protocoll to connect the 2 offices.
satman1w
Re: Best VPN
Thu Mar 05, 2020 2:46 pm
You can use IPIP or GRE tunnel with IPsec!
It will do the job perfectly
regards
nacu62
Re: Best VPN
Thu Mar 05, 2020 4:59 pm
regards
to use ipsec dont you need only ip static?
satman1w
Re: Best VPN
Thu Mar 05, 2020 5:09 pm
No!
A simple script will fill in right address every time it changes..
Tested on numerous installations..
regards
Users browsing this forum: antleo, Bing [Bot], Unibits and 99 guests
