MUM Europe 2020
Rick
Firewall block list
Fri Feb 14, 2020 1:35 pm
I have a PPTP server running on my router, and occasionally get brute force attempts on the login.
I periodically block these IPs, however I have noticed that the blocklist I have is not working.
Here is the connection I am attempting to block (I left his IP in ha)
input: in:Eth1-Outside out:(unknown 0), src-mac 50:5d:ac:4e:82:24, proto TCP (SYN), 92.63.194.27:44684->x.x.x.x:1723, len 60
The firewall rule I have is (1st rule):
/ip firewall address-list
add address=141.98.80.115 list=Blocked
add address=162.243.140.155 list=Blocked
add address=92.63.194.27 list=Blocked
add address=185.232.67.13 list=Blocked
add address=46.161.27.42 list=Blocked
add address=92.63.194.47 list=Blocked
add address=141.98.80.128 list=Blocked
add action=drop chain=input comment="Blocked IPs" log=yes src-address-list=Blocked
Does the OS accept the PPTP before the firewall or something? How can I block these unwanted IPs?
msatter
Re: Firewall block list  [SOLVED]
Fri Feb 14, 2020 2:10 pm
Have you tried to block in /ip firewall raw which earlier active than Filter?
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.47.beta.x / Winbox 3.21 / MikroTik APP 1.3.10
Android device owners, use https://github.com/M66B/NetGuard/releases (no root required)
Rick
Fri Feb 14, 2020 2:50 pm
Yes that worked, thank you !!!
Users browsing this forum: Bing [Bot], imdadali, k6ccc, McSee, robo, SiB, stanelie and 123 guests
