swisstico
FastTrack in Mangle table?
Fri Mar 13, 2020 8:55 pm
Hello everyone,
Studying fast track, we could see that in a default configuration FastTrack is on Filter table.
What are the reasons not putting it in mangle table instead to process as soon as possible?
Thanks for your answers!
swisstico
Re: FastTrack in Mangle table?
Wed Mar 25, 2020 10:55 pm
Up please :D
msatter
Wed Mar 25, 2020 11:05 pm
It doesn't make much difference because the the way FastTrack works. After it is activated only sporadic traffic is sent through the normal rules.
Have also a look at notrack in RAW which speeds up traffic by bypassing the connections table.
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.47.beta.x / Winbox 3.21 / MikroTik APP 1.3.12
NordVPN viewtopic.php?f=2&t=158439&p=781009 for multiple connections.
swisstico
Fri Mar 27, 2020 9:44 pm
Thanks for your answer :D
Users browsing this forum: anav, bpolat, magistryoda, rjdza, ryanwilliams83 and 56 guests
