Didnt want to create new topic so i will use this one.
I have problems getting ROS v3 to run on my old compi.
Its an Celeron 366 on mobo with VIA chipset (Apollo PRO133)
System hungs just after showing
"Uncompressing Linux... OK, booting the Kernel"
Its an beta 9 version.
I installed it on 128Mb CF Kingston on Toshiba CF-IDE adapter.
I had no problems with 2.8 and 2.9 versions of ROS.
The system works fine on my other ompi, Sepmpron 64bit 2.6 on Gigabyte mobo with VIA K8T800 chipset.
I hope next beta will solve this
