I've a CRS309 (ver. 6.46.3), and trying to limit b/w on per VLAN bases using switch rules as described here: https://wiki.mikrotik.com/wiki/Manual:C ... ic_Shaping . But somehow these rules do not seem to have any effect in terms of traffic shaping. Following is my running configuration. Please point out if I've missed something.
Code: Select all
set [ find default-name=sfp-sfpplus1 ] advertise="10M-half,10M-full,100M-half,\
100M-full,1000M-half,1000M-full,2500M-full,10000M-full"
set [ find default-name=sfp-sfpplus2 ] advertise="10M-half,10M-full,100M-half,\
100M-full,1000M-half,1000M-full,2500M-full,5000M-full,10000M-full" \
auto-negotiation=no speed=10Gbps
set [ find default-name=sfp-sfpplus8 ] advertise="10M-half,10M-full,100M-half,\
add frame-types=admit-only-vlan-tagged name=Bridge protocol-mode=none \
vlan-filtering=yes
/interface vlan
add interface=Bridge name=MGMT_V99 vlan-id=99
add bridge=Bridge interface=sfp-sfpplus1
add bridge=Bridge interface=sfp-sfpplus2
add bridge=Bridge interface=sfp-sfpplus3
add bridge=Bridge interface=sfp-sfpplus4
add bridge=Bridge interface=sfp-sfpplus5
add bridge=Bridge interface=sfp-sfpplus6
add bridge=Bridge interface=sfp-sfpplus7
add bridge=Bridge interface=sfp-sfpplus8
add bridge=Bridge interface=ether1
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-vlan=yes
/interface bridge vlan
add bridge=Bridge tagged=Bridge,sfp-sfpplus8 vlan-ids=99
add bridge=Bridge tagged=sfp-sfpplus1,sfp-sfpplus8 \
vlan-ids=501
vlan-ids=502
vlan-ids=503
vlan-ids=504
vlan-ids=505
add bridge=Bridge tagged=\
sfp-sfpplus1,sfp-sfpplus6 vlan-ids=521
add bridge=Bridge tagged=sfp-sfpplus1,sfp-sfpplus6 vlan-ids=522
sfp-sfpplus1,sfp-sfpplus6 vlan-ids=601
sfp-sfpplus1,sfp-sfpplus6 vlan-ids=602
sfp-sfpplus1,sfp-sfpplus6 vlan-ids=603
add bridge=Bridge tagged=sfp-sfpplus1,sfp-sfpplus6 \
vlan-ids=604
vlan-ids=1002
vlan-ids=552
vlan-ids=553
vlan-ids=551
vlan-ids=805
vlan-ids=804
vlan-ids=806
vlan-ids=807
vlan-ids=554
vlan-ids=809
vlan-ids=803
vlan-ids=3175
vlan-ids=1003
vlan-ids=1004
vlan-ids=555
vlan-ids=556
vlan-ids=557
vlan-ids=558
vlan-ids=559
vlan-ids=1009
add bridge=Bridge tagged=sfp-sfpplus1,sfp-sfpplus8 vlan-ids=723
sfp-sfpplus1,sfp-sfpplus8 vlan-ids=560
/interface ethernet switch rule
add ports=sfp-sfpplus6,sfp-sfpplus1 rate=1100M switch=switch1 vlan-id=521
add ports=sfp-sfpplus6,sfp-sfpplus1 rate=400M switch=switch1 vlan-id=602
Thank you.
Rahul
