vortex
Edge caching
Mon Mar 23, 2020 1:17 pm
Are people ramping up this?
idlemind
Re: Edge caching
Mon Mar 23, 2020 11:32 pm
The SSL/TLS of all things have nuked most of this without help from upstreams like getting dedicated boxes from CDN and provider services.
Not as easy to put an HTTP proxy inline anymore and get significant bandwidth savings.
vortex
Re: Edge caching
Mon Mar 23, 2020 11:42 pm
But wouldn't something like LanCache work for ISPs too to cache the main game CDNs?
idlemind
Re: Edge caching
Tue Mar 24, 2020 12:21 am
All technology specific. That works and requires DNS as far as I'm aware. As long as your customers are using your DNS you'd have the option to use that.
Either way it's a game of managing all of these specific types of caches. Another example that scales better than that is caching for Apple updates, I think that still requires an Apple OS X box though.
vortex
Re: Edge caching
Tue Mar 24, 2020 12:29 am
Yes, it works by pointing the CDN names to your cache. Those servers are cleartext.
https://github.com/uklans/cache-domains
If someone uses a non-ISP DNS server it is their problem, most home users won't bother doing that.
I saw an unrelated example of setting the DNS server address in a PS4 to download much faster from somewhere else.
idlemind
Re: Edge caching
Tue Mar 24, 2020 1:20 am
If you want the maintenance burden I'd say do it. The only way I'd really consider it is if their were other constraints like significant geographical latency or am inability to obtain more transport. This is because the maintenance burden of keeping up with too many individual, custom, caching techniques has a cost too. It takes the shape of reputational damage when a customer experiences an issue due to your caching middleware. You also experience cost when someone does bother to call you for support and you have to spend time troubleshooting. Caching doesn't mean free bandwidth but in some situations it may be cheaper to try. That's a calculation you have to make though.
vortex
Re: Edge caching
Tue Mar 24, 2020 1:50 am
But if you can serve content faster than the CDN would, it is a marketing tool.
vortex
Re: Edge caching
Tue Mar 24, 2020 7:38 pm
PSN is temporarily reducing download speeds in Europe given that the EU asked streaming services to consume less bandwidth.
MS and Akamai will also be managing game downloads if there's congestion.
vortex
Re: Edge caching
Thu Mar 26, 2020 2:49 am
Steam would saturate a 500 Mbps connection a while back.
More recently I have not seen it download more than half as quickly.
I checked and the content comes from the CDN far away, there's no "local" server.
I started monitoring some weeks ago and I am paying for too much bandwidth.
vortex
Re: Edge caching
Fri Mar 27, 2020 7:10 pm
Some online games are overloaded, not downloads.
vortex
Re: Edge caching
Sat Mar 28, 2020 3:10 am
I found a Mikrotik DNS example thread:
viewtopic.php?t=92293
But you can also just use lancache as DNS proxy.
Note that some game download clients will use HTTPS if the cache IP address is public, so an ISP could not simply use the standard config.
vortex
Re: Edge caching
Sun Mar 29, 2020 2:21 am
I see people complaining that PSN downloads are really slow.
And many people don't understand why they have to delete stuff to download a "small" update.
vortex
Re: Edge caching
Tue Mar 31, 2020 1:31 am
Steam is also doing some bandwidth management unrelated to their capacity.
Users browsing this forum: jamrobe and 146 guests
