syadnom
LoRa empty time field for gateway
Mon Mar 23, 2020 11:01 pm
We are seeing an empty 'time' field in the lorawan forwarded packets. This is non-standard. We should see an actually system time, or that field should be omitted. Any ideas? up-to-date firmware.
keksdom
Re: LoRa empty time field for gateway
Thu Mar 26, 2020 12:28 pm
And I am also interested in this question.
And also, if you use LtAP + R11e-LoRa8 + pigtail + LoRa Antenna kit, will the "timeSinceGpsEpoch:" indicator come to the server?
All this is necessary to more accurately calculate the location of the transmitting device.
И меня тоже интересует этот вопрос. А так же если использовать LtAP + R11e-LoRa8 + пигтейл + LoRa Antenna kit будет ли приходить на сервер показатель "timeSinceGpsEpoch:"?
Это всё необходимо для более точного вычисления местоположения передающего устройства.
normis
Thu Mar 26, 2020 5:39 pm
Thanks, we will start including time in the next RouterOS versions.
syadnom
Fri Mar 27, 2020 6:31 pm
Which version? Next stable or next beta? Can I get this by installing the 6.47beta49?
keksdom
Mon Mar 30, 2020 3:50 pm
I also ask you to pay attention to the fact that LtAP with a GPS module does not send its position to the network server. Specially assembled the LTAP mini + Lora8 scheme; the timestamp is not sent with "timeSinceGpsEpoch:".
Another question that interests you is whether you plan to create the ability to use R11e-LoRa8 at the point of LtAP as a client, for example, for GPS tracking? It would be interesting to use such a set in a car.
Do you plan to integrate a GPS module in the following wAP LoRa8 kit models?
We are waiting for a firmware update from you.
Thank you in advance.
Так же прошу обратить Ваше внимание, на то что LtAP mini c GPS модулем не присылает сетевому серверу своё место положение. Специально собрал схему LtAP mini + R11e-LoRa8 - временная метка не присылается с "timeSinceGpsEpoch:".
Ещё интересует вопрос, планируете ли Вы создать возможность использовать R11e-LoRa8 в точке ЛтАП как клиента, например для GPS трекинга? Интересно было бы использовать такой набор в автомобиле.
Планируете ли Вы в следующих моделях wAP LoRa8 kit встроить GPS модуль?
Ждём от Вас обновления прошивки.
За ранее спасибо.
keksdom
Mon Apr 06, 2020 12:50 pm
Thank you, updated the firmware 6.47beta54 (Testing), the time is coming.
Any answer on the previous post? Very interested ..
Спасибо, прошивку обновил 6.47beta54 (Testing), время приходит.
Что-то ответите по предыдущему посту? Очень интересует..
syadnom
Mon Apr 06, 2020 3:28 pm
Really need gps+time , and really the time needs to be pulled from gps so trilateration is more accurate.
Users browsing this forum: Google [Bot], Kindis, martinclaro and 161 guests
