BogaBY
WinBox Connection error
Tue Mar 24, 2020 5:02 pm
winbox error : router does not support secure connection, please enable legacy mode if you want to connect anyway.
Winbox - 3.22
RB1100AHx4 - 6.46.4
And see attachment.
Any idea?
MrDAnderson
Re: WinBox Connection error
Wed Mar 25, 2020 8:03 pm
I had the same problem, the best you go back to the previous version
pukkita
Trainer
Trainer
Wed Mar 25, 2020 9:19 pm
You need to enable set Tools > Legacy Mode in WinBox
Once you log on, Make sure System > Routerboard Current vs Upgrade Firmware is the same, otherwise click on Upgrade and reboot.
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
Kindis
Wed Mar 25, 2020 11:11 pm
So I wonder if the new secure winbox connection cannot handle NAT.
Was setting up a new router that I pre configured but managed to frogg up the OSPF config on the new one.
GRE connected but I had to NAT my connection to get route back and Winbox did not want to connect with legacy mode on or off.
Used SSH to fix my config and once NAT was off Winbox worked again.
Just a guess but this might be how they solve man in the middle attacks but this creates the issue that I cannot force my router to use legacy mode if all this is true.
Edit: What I mean is that I think new Winbox security cannot handle stuff like NAT that "tamper" with the header of the package. Once again just a guess and I have not tested.
BogaBY
Thu Mar 26, 2020 9:40 am
Current Firmware and Upgrade Firmware is the same = 6.46.4
https://prnt.sc/rmzrdn
hrcho
Thu May 28, 2020 7:47 pm
The same problem on RB4011iGS+RM v. 6.46.6 and winbox v. 3.24.
Legacy Mode didn't work either.
Reboot solved the problem, but temporarily.
Bruster
Sun Feb 14, 2021 6:33 pm
I'm facing the same issue on 6.48.1
Before issue occur I added 22k static dns records to setup smth like ad block functionality. Had only 27 mb RAM available after that.
Normally, before import, ~100 mb RAM was available (lovely days) which means that import resulted in permanent loss of 73 mb of ram.
Looks like memory leak. Tried to flush dns cache but operation was failed due to timeout. Several tries after and one finished w\o errors but cache was not cleaned actually.
Reverted everything back thanks to backup.
RB962UiGS-5HacT2HnT
Users browsing this forum: gadmin01, liuyao, satman1w and 163 guests
