essides
ARP Between VPN
Tue Mar 24, 2020 6:08 pm
I have some VPN clients ( PPTP , L2TP ) and I want they can find each other as in a LAN
How can I do it ?
Thanks you.
bpwl
Re: ARP Between VPN
Wed Mar 25, 2020 12:42 am
LAN access is over bridge. To have the VPN's on the VPN server connected via bridge, I assume you just set this default bridge in the "PPP profile", and use that profile in all PPTP and L2TP VPN .
More info (but different case) : https://wiki.mikrotik.com/wiki/Manual:B ... _bridging)
essides
Re: ARP Between VPN
Wed Mar 25, 2020 1:40 am
Yes, both VPN services use same profile with bridge option selected.
Selected bridge have arp-proxy selected.
Does it work with this config?
Final clients are using Windows OS, so I cant configure BCP protocol.
Thanks you.
kahid
Re: ARP Between VPN
Wed Mar 25, 2020 10:19 am
Thanks you.
Hi buddy, thanks for this thread, was facing similar issues as of now. Got it solved via this thread.
Regards,
K. Smith
Regards,
K. Smith
essides
Re: ARP Between VPN
Wed Mar 25, 2020 4:22 pm
Thanks you.
Regards,
K. Smith
How did you get it?
Cause my vpn clients can't see physical address each other
tdw
Re: ARP Between VPN
Wed Mar 25, 2020 10:20 pm
If you use a conventional IP / layer 3 VPN, you have no access to the MAC / layer 2 information at the other end.
Proxy-arp allows a router to provide its own MAC address to allow communication between devices using the same subnet IP addresses but attached to differing physical networks, e.g. a local LAN and a VPN client. If you really need layer2 access you will have to use EoIP, possibly OpenVPN tunnel mode although I haven't tried the latter.
Users browsing this forum: andriys, arxdust and 170 guests
