mrmut
SSTP VPN / Issue users connect but can't go anywhere
Tue Mar 24, 2020 9:27 pm
I have a Mikrotik device for local WiFi. As we have Coronacrap now, I tried to configure VPN.
I made server and root certificates, configured SSTP, and forwarded the port 443 to the MikroTik.
Users can connect, but I they don't see local network and can't connect to NAS over IP.
I tried turning off the Firewall for testing, and tried to compare configuration with another MikroTik but couldn't find out what is wrong. I am pretty sure something stupid in Q, but don't know what.
Any help appreciated, config below:
add admin-mac=64:D1:54:5D:D7:7E auto-mac=no comment=defconf fast-forward=no name=bridge
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=ether2-master
set [ find default-name=ether3 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether4 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether5 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=2 band=2ghz-onlyn basic-rates-a/g=12Mbps basic-rates-b="" disabled=no \
    distance=indoors frequency=2452 installation=indoor mode=ap-bridge rate-set=configured ssid=PRIJATELJI \
    supported-rates-a/g=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b="" wireless-protocol=802.11 wps-mode=\
    disabled
set [ find default-name=wlan2 ] antenna-gain=2 band=5ghz-n/ac basic-rates-a/g=12Mbps channel-width=20/40mhz-Ce disabled=\
    no distance=indoors frequency=5200 installation=indoor mode=ap-bridge rate-set=configured ssid=PRIJATELJI \
    supported-rates-a/g=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps wireless-protocol=802.11 wps-mode=disabled
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=vpn ranges=192.168.13.100-192.168.13.200
add address-pool=dhcp authoritative=after-2sec-delay interface=bridge name=defconf
/ppp profile
add dns-server=192.168.5.1,192.168.5.42 local-address=192.168.5.13 name=VPN on-down=\
    ":for i from=1000 to=40 step=-20 do={\r\
    \n  :beep frequency=\$i length=11ms;\r\
    \n  :delay 11ms;\r\
    \n}" on-up=":beep frequency=660 length=100ms;\r\
    \n:delay 150ms;\r\
    \n:beep frequency=660 length=100ms;\r\
    \n:delay 300ms;\r\
    \n:delay 300ms;\r\
    \n:beep frequency=510 length=100ms;\r\
    \n:delay 100ms;\r\
    \n:delay 300ms;\r\
    \n:beep frequency=770 length=100ms;\r\
    \n:delay 550ms;" remote-address=vpn
add bridge=bridge interface=ether2-master
add bridge=bridge interface=wlan1
add bridge=bridge interface=wlan2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add bridge=bridge interface=ether1
set discover-interface-list=discover
add interface=ether2-master list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=wlan1 list=discover
add interface=wlan2 list=discover
add interface=bridge list=discover
add interface=bridge list=mactel
add interface=bridge list=mac-winbox
/interface sstp-server server
set authentication=mschap2 certificate=Server default-profile=VPN enabled=yes force-aes=yes pfs=yes tls-version=only-1.2
add address=192.168.5.2/24 comment=defconf interface=ether2-master network=192.168.5.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1m
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=bridge
add address=192.168.5.0/24 comment=defconf gateway=192.168.5.2 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.5.2 name=router
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes protocol=icmp
add action=accept chain=input comment="defconf: accept established,related" connection-state=established,related \
    disabled=yes
add action=accept chain=input comment="SSTP in (443)" disabled=yes dst-port=443 log=yes log-prefix="SSTP in (443)" \
    protocol=tcp
add action=drop chain=input comment="defconf: drop all from WAN" disabled=yes in-interface=ether1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related disabled=\
    yes
add action=accept chain=forward comment="defconf: accept established,related" connection-state=established,related \
    disabled=yes
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new disabled=yes in-interface=ether1
# in/out-interface matcher not possible when interface (ether1) is slave - use master instead (bridge)
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=ether1
/ppp secret
add name=prijateljivpn profile=VPN
/system clock
set time-zone-name=Europe/Zagreb
/system logging
add topics=sstp
/system package update
set channel=long-term
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
Zacharias
Re: SSTP VPN / Issue users connect but can't go anywhere
Tue Mar 24, 2020 11:33 pm
You should add a route on the VPN client for the local subnet...
mrmut
Wed Mar 25, 2020 3:10 pm
I tried, but that didn't help (or I did it wrong).
Then I tried adding a masq and everythign worked:
add action=masquerade chain=srcnat comment="MASKA ZA VPN" out-interface=bridge
Is this the right way to do this?
Zacharias
Wed Mar 25, 2020 9:56 pm
If you masquerade then basically you perform NAT and the packet that leaves the Bridge has the Address of the Bridge interface...
So the SSTP client will be seeing the routers Bridge Address and not the Client's who is behind the Router...
All depends on your whole config... Since it didnt work before, then the packet was marked most likely as invalid...
I dont see any adress in the Bridge on your config above...
mrmut
Thu Mar 26, 2020 11:27 am
I have an address on my eth2 192.168.5.2, and a DHCP one of 192.168.5.42 on the bridge.
It seems to me that I did a misconfiguration on VPN - I should have put local address on VPN pool... to 192.168.13.1
If I understand correctly, I would have to make a route that sends packets destined to local network, from VPN network, like this? ->
/ip route add dst-address=192.168.5.0/24 gateway=192.168.13.1
(Thanks and sorry for the stupid Qs.)
joenorx
Thu Mar 26, 2020 6:47 pm
Dear Support,
Please I'm new using Mikrotik device, I have this Hospital Management System connected to a Mikrotik hEx Lite, But I have set up a PPTP on the router I notice I can't connect to it from another network, as it says 'network taking too long to respond' I wanted a situation whereby I can access the Hospital Management System from my home, but notice all attempted proved abortive, as I can not connect to the router at the hospital from another network.
Please can someone help?
Regards,
Joseph
Zacharias
Thu Mar 26, 2020 8:34 pm
Yes correct...
Also, you should use bridges... and when you do, you set the Address on the Bridge and not at the slave interface...
joenorx
Fri Mar 27, 2020 9:34 am
@ Zacharias Are you refering to me from the post?
Yes correct...
mrmut
Fri Mar 27, 2020 9:55 am
As aI really shouldn't break stuff remotely, I am testing this on my home router. Will post back if all worked.
Thanks for help!
Users browsing this forum: Chupaka, echesortux, MSN [Bot], nolitolits, Torin and 106 guests
