nichky
Long time Member
Long time Member
{ASK} apsman with local-forwarding=no
Wed Mar 25, 2020 12:47 am
i'm using capsman with local-forwarding=no
i have noticed i'm still able to ping clients connected to the AP.
any tips about that?
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
!) Safe Mode is your friend;
eworm
Long time Member
Long time Member
Re: {ASK} apsman with local-forwarding=no
Wed Mar 25, 2020 12:57 am
This setting controls whether or not to tunnel traffic to the capsman device.
Any reason why a ping to a client should not succeed?
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
nichky
Long time Member
Long time Member
Wed Mar 25, 2020 1:00 am
capsman local-forwarding=no is not same like
int wla local-forwarding=no?
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
eworm
Long time Member
Long time Member
Wed Mar 25, 2020 1:06 am
Have a look at Local Forwarding Mode and Manager Forwarding Mode.
Probably you want to control client-to-client forwarding on capsman?
nichky
Long time Member
Long time Member
Wed Mar 25, 2020 1:09 am
i did that too,stil i can ping the client from my com
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
eworm
Long time Member
Long time Member
Wed Mar 25, 2020 1:20 am
AFAIK this setting only handles wireless client to wireless client.
Your echo request comes from the wired side of CAP?
nichky
Long time Member
Long time Member
Wed Mar 25, 2020 1:42 am
of course i'm pinging wireless client. from my laptop
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
eworm
Long time Member
Long time Member
Wed Mar 25, 2020 7:46 am
And your laptop is connected to the same CAP wirelessly?
nichky
Long time Member
Long time Member
Wed Mar 25, 2020 8:12 am
correct
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
eworm
Long time Member
Long time Member
Wed Mar 25, 2020 8:36 am
Then it's indeed unexpected behavior. Probably nobody here can help any further, contact support if this bothers you.
nichky
Long time Member
Long time Member
Sun Mar 29, 2020 10:55 am
can i ask one more question.
im doing Capsman with vlans, and of course local forwarding is enabled.
im geting ip from the CAP pool, but can't ping out,from the CPE when im pingign to google src-address=local i can ping out.
My config is:
Capsman
/caps-man provisioning
add action=create-enabled master-configuration=Config_wifi
name-format=prefix-identity
/caps-man configuration
add datapath.client-to-client-forwarding=no datapath.local-forwarding=yes datapath.vlan-id=10 datapath.vlan-mode=use-tag mode=ap name=Config_wifi ssid=WiFi
CAP
/interface vlan
add interface=local-lan name=vlan10 vlan-id=10
add address=10.0.3.2/30 interface=ether1 network=10.0.3.0
add address=10.0.0.3 interface=lo0 network=10.0.0.3
add address=10.11.1.1/24 interface=vlan10 network=10.11.1.0
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
Users browsing this forum: jamrobe and 170 guests
