I have ipsec vpn established between a cisco router and a mikrotik router.
But i am unable to ping host pcs connected.
Attached is the snapshot of the routes in the mikrotik.
Kindly assist
# may/16/2020 22:09:48 by RouterOS 6.46.6
# software id = RXZI-3K8X
# model = RB760iGS
# serial number = A36A0B953574
add admin-mac=C4:AD:34:D8:DB:2D auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment=WAN
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip ipsec policy group
add name=Comits
/ip ipsec profile
add dh-group=modp2048 enc-algorithm=aes-128 hash-algorithm=sha256 name=Comits
/ip ipsec peer
add address=REMOTEWAN exchange-mode=ike2 local-address=MYWAN name=\
Comits port=500 profile=Comits
/ip ipsec proposal
add auth-algorithms=sha256 enc-algorithms=aes-128-cbc lifetime=1d name=Comits \
pfs-group=modp2048
add name=dhcp ranges=192.168.15.10-192.168.15.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=sfp1
/interface detect-internet
set detect-interface-list=all
add address=192.168.15.1/24 comment=defconf interface=ether2 network=\
192.168.15.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.15.0/24 comment=defconf gateway=192.168.15.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.15.1 comment=defconf name=router.lan
add action=accept chain=input dst-port=500,4500 protocol=udp
add action=accept chain=forward dst-address=192.168.5.0/24 src-address=\
192.168.15.0/24
add action=accept chain=forward dst-address=192.168.1.0/24 src-address=\
192.168.15.0/24
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=accept chain=srcnat dst-address=192.168.5.0/24 src-address=\
192.168.15.0/24
add action=accept chain=srcnat dst-address=192.168.1.0/24 src-address=\
192.168.15.0/24
/ip ipsec identity
add peer=Comits policy-template-group=Comits
/ip ipsec policy
add dst-address=192.168.1.0/24 peer=Comits proposal=Comits sa-dst-address=\
94.137.134.194 sa-src-address=MYWAN src-address=192.168.15.0/24 \
tunnel=yes
add dst-address=192.168.5.0/24 peer=Comits proposal=Comits sa-dst-address=\
tunnel=yes
add distance=1 dst-address=192.168.1.0/32 gateway=ether1
add distance=1 dst-address=192.168.5.0/32 gateway=ether1
/system clock
set time-zone-name=Europe/Copenhagen
/tool mac-server
/tool mac-server mac-winbox
Unlike routes, the rules in firewall (and multiple other configuration branches) are matched in sequential order, not by best match. Hence you have to move the two action=accept rules in chain=srcnat of /ip firewall nat before (above) the action=masquerade one.The Tunnel is established, but can't ping.
This is only relevant when you assign to your VPN clients addresses which fit into your LAN subnets. That's not the case here.If you use ipsec and need to access local resources, then set the Proxy-arp option for the Bridge interface.
DoneUnlike routes, the rules in firewall (and multiple other configuration branches) are matched in sequential order, not by best match. Hence you have to move the two action=accept rules in chain=srcnat of /ip firewall nat before (above) the action=masquerade one.The Tunnel is established, but can't ping.
Done
Also the first two rules in chain=forward of /ip firewall filter should be redundant (not harmful), as the next two ones from the default configuration, action=accept ipsec-policy=(in|out),ipsec, should do their job of preventing packets handled by IPsec policies from reaching the action=fasttrack-connection rule.
My local WAN is: xx.xx.1.136What do the installed SA show under IP->IPsec?
There should be two per each remote subnet. If both count packets and bytes while you ping, the issue is at the Mikrotik end; if only the one from Mikrotik to Fortigate counts, it is an issue with IPsec itself or the firewall at the Fortigate end.
Try to add a chain=input action=accept protocol=ipsec-esp rule to /ip firewall filter, as the very first one in chain=input - it is not the right final place for it but it is to check what the issue may be.
No different.
Since both devices have public IP addresses, they use ESP as transport protocol. The transport packets only come if they have any payload to carry, so there are three possible reasons why no ESP packets arrive as the installed SA table shows:
- the remote device doesn't respond your pings or it doesn't have a route to your subnet via the Fortigate box, hence the Fortigate gets nothing to send in the ESP
The Fortigate's respond is working and there is a route to my local network. The Mikrotik as replaced a Ubiquity ER-X, where the VPN worked. Nothing has been changed in the Fortigate's firewall or other settings. I'm sure about that, as i am also the admin of that one.- something on the path between the Fortigate and the Mikrotik drops ESP
- something has changed in the firewall implementation on Mikrotik and the "accept established" rule doesn't accept incoming ESP packets although the Mikrotik did send ones in the opposite direction
