Term
Homeoffice - VPN
Wed Mar 25, 2020 9:17 pm
I'm trying to create VPN from my home's mikrotik to work. How can I do that?
I already created VPN connection but my computer still can't access to company's network.
Have more computers at home but want to be able to access company's network from one computer only.
Thank you for your tips.
tdw
Re: Homeoffice - VPN
Wed Mar 25, 2020 10:07 pm
If you only wish one computer to access your company network it would be far simpler to set up VPN connections from that one computer.
szymonzdziabek
Wed Mar 25, 2020 10:09 pm
If you try to connect to the company network, you should create a VPN connection on your PC, not on your router. Or not, if you would like to have site2site link.
Term
Wed Mar 25, 2020 10:17 pm
Yes but I don't want to make VPN connection in computer because of another VPN.
Sob
Wed Mar 25, 2020 11:22 pm
Likely solution:
add chain=srcnat out-interface=<your VPN interface> action=masquerade
And then to limit access (assuming you have default firewall or other with standard rules to allow established connections):
add chain=forward src-address=<your PC in LAN> out-interface=<your VPN interface> action=accept
add chain=forward out-interface=<your VPN interface> action=reject
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
Term
Thu Mar 26, 2020 8:53 pm
Ok I followed your guide. Doesn't work. Still can't connect to compan without VPN in computer
Sob
Thu Mar 26, 2020 9:44 pm
That's the problem with blind guesses, sometimes they succeed and sometimes they don't. But without anything specific, exported config for example, it's difficult to do more.
ninja365
Sun Mar 29, 2020 12:20 pm
You can have multiple VPN connections on a PC so that would be a much simpler solution.
Sent from my moto g(7) plus using Tapatalk
Users browsing this forum: echesortux, erlinden, Kazek, Kindis, martinclaro, mrz, nolitolits and 149 guests
