msatter
TLS Host glob format?
Thu Mar 26, 2020 5:41 pm
I was looking at using an expression in TLS Host but I can't get it to work. I press TAB then I get the following possibilities:
"  $  ?  [0-9A-F]  \  _  a  b  f  n  r  t  v
$ = end of string
? = one or zero characters/signs/figures
[0-9A-Z] = in a range
\ = escape character
_ = used in domain names
a =
b =
f =
n = (maybe newline)
r = (maybe return)
t = (maybe tab)
v = (maybe vertical tab)
I really don't know were a b f n r t v are standing for.
A simple line with tls-host="^www\\.mikrotik\\.com$" seems not to work despite the packet (TCP) is not fragmented. Working is
www.mikrotik.com
I am missing grouping (aaa|bbb) which would very nice to have.
The page pointed to by the Wiki does not makes me much wiser: https://en.wikipedia.org/wiki/Glob_(programming)
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.47.beta.x / Winbox 3.21 / MikroTik APP 1.3.12
NordVPN viewtopic.php?f=2&t=158439&p=781009 for multiple connections.
Sob
Re: TLS Host glob format?
Thu Mar 26, 2020 7:14 pm
It's not regexp, and TAB doesn't show anything here. These work:
/ip firewall mangle
add action=log chain=prerouting dst-port=443 log-prefix=tls-forum protocol=tcp tls-host=forum.mikrotik.com
add action=log chain=prerouting dst-port=443 log-prefix=tls-any protocol=tcp tls-host=*.mikrotik.com
add action=log chain=prerouting dst-port=443 log-prefix=tls-any+m protocol=tcp tls-host=*m.mikrotik.com
add action=log chain=prerouting dst-port=443 log-prefix=tls-w+any protocol=tcp tls-host=w*.mikrotik.com
add action=log chain=prerouting dst-port=443 log-prefix=tls-any+m/w protocol=tcp tls-host="*[mw].mikrotik.com"
add action=log chain=prerouting dst-port=443 log-prefix=tls-3a-z protocol=tcp tls-host="[a-z][a-z][a-z].mikrotik.com"
add action=log chain=prerouting dst-port=443 log-prefix=tls-5a-z protocol=tcp tls-host="[a-z][a-z][a-z][a-z][a-z].mikrotik.com"
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
msatter
Thu Mar 26, 2020 7:45 pm
Thanks Sob but that help is really there if you are on one of the "\\" and press tab:
I can enter the characters show by help in terminal (look at the orange $), and it is accepted on enter, but in the Winbox interface shows a blank field.
Running:
Users browsing this forum: andriys, arxdust, bpolat, hschnei and 163 guests
