IntraLink
Quick upgrade question
Sun Dec 12, 2004 8:45 pm
When I upgrade via ftp I usually upload the system package, reboot and then upload all of the utility packages.
I think with this method I lose the settings, like the wireless configuration etc, right?
Can I just upload the system and all of the utility packages at once and expect it to upgrade everything on reboot and keep the settings?
Thanks for your help!
mip
Sun Dec 12, 2004 9:14 pm
We did it several times, and it works.
https://www.youtube.com/watch?v=j7q0Y_JZMrg - the country you must visit
wildbill442
Mon Dec 13, 2004 5:33 am
just upgraded three of our MT's this way (upload everything and reboot) no problems no configuration losses. Should work fine.
stephenpatrick
Forum Veteran
Forum Veteran
Mon Dec 13, 2004 12:52 pm
Suggest ftp **all** the packages you want, then reboot.
Remember to include only ONE of the wireless packages (standard or legacy).
Worked fine for 6 different upgrades of RouterOS with wireless
I think upgrading just "system" then the others later is creating the problems you describe, the packages will be out of step with the system portion.
Regards
CableFree - Wireless Excellence - Microwave, E-band Radios, Free Space Optics, High performance Radios & Routers
http://www.cablefree.net
Users browsing this forum: cedie, dioeyandika, Google [Bot], madmucho, wichets and 49 guests
