idanmikos
Winbox Quick Set strange Local network IP
Sat Mar 28, 2020 11:25 pm
Hi all,
Newbie but willing to learn, configured a Hex3 as router with two WAN's, ISP1 and ISP2 on ethernet1 and 2 with failover.
Here is is my config
# mar/28/2020 22:43:00 by RouterOS 6.46.4
# software id = L5WD-NLXH
# model = RouterBOARD 750G r3
# serial number = 6Fxxxxxx1
add admin-mac=6C:xx:xx:xx:xx:xx arp=proxy-arp auto-mac=no comment=defconf \
    name=bridge
set [ find default-name=ether1 ] comment=ISP1 name=ether1-ISP1
set [ find default-name=ether2 ] comment=ISP2 name=ether2-ISP2
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=VPN_pool ranges=192.168.88.101-192.168.88.110
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
add dns-server=xxx.y.y.z,xxx.y.y.w local-address=VPN_pool name=\
    VPN_profile remote-address=VPN_pool
add comment=defconf interface=ether1-ISP1 list=WAN
/interface pptp-server server
set authentication=chap,mschap1,mschap2 default-profile=VPN_profile enabled=\
    yes mrru=1600
    192.168.88.0
add address=x.y.z.69/24 interface=ether1-ISP1 network=5.2.255.0
add address=192.168.z.ww/24 interface=ether2-ISP2 network=192.168.z.0
/ip dhcp-client
add comment=defconf
/ip dhcp-server lease
add address=192.168.88.36 client-id=1:0:aa:aa:ed:16:46 comment=\
    "Brother" mac-address=00:80:77:xx:zz:46 server=defconf
add address=192.168.88.23 client-id=1:0:aa:aa:d0:bf:15 mac-address=\
    00:10:20:D0:xx:zz server=defconf
add address=192.168.88.100 client-id=1:aa:aa:aa:e2:f1:bf comment=\
    "Dell" mac-address=74:E6:dd:vv:ff:BF server=defconf
add address=192.168.88.105 client-id=1:ff:fdf:zz:cc:ww:ad comment=\
    "Dell 2" mac-address=74:hh:hh:gg:23:AD server=defconf
set allow-remote-requests=yes servers=\
    2xx.rrr.g.gg,2xx.rrr.g.1,1aa.vvv.a.31,1aa.vvv.a.30
/ip dns static
add address=192.168.88.1 name=router.lan
    established,related,untracked
add action=accept chain=input comment="PPPT VPN" dst-port=1723 protocol=tcp
add action=accept chain=input comment=winbox dst-port=8291 protocol=tcp
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    ipsec-policy=out,none out-interface=ether1-ISP1
add action=masquerade chain=srcnat out-interface=ether2-ISP2
add distance=1 gateway=x.y.aa.1
add check-gateway=ping distance=2 gateway=192.168.8.1
/ip service
set www-ssl address=192.168.88.0/24
/ip smb
set domain=HOMEGROUP
/ip ssh
set forwarding-enabled=remote
/ppp secret
add name=ppp1 profile=VPN_profile service=pptp
/system clock
set time-zone-name=Europe/Bucharest
/system identity
set name=netisol
/tool mac-server
/tool mac-server mac-winbox
The router works well since 2 months but today I have just noticed in Winbox Quick Set that Local Network IP is in fact the second ISP's IP.
If I connect to my router from some LAN desktop via browser, I use the correct IP 192.168.88.1 address and it works.
Attached is a screenshot of Quick Set.
Any clues on what may be wrong with my router config?
Thank you.
Dan
Sob
Re: Winbox Quick Set strange Local network IP
Sun Mar 29, 2020 12:09 am
Simple rule is that once you do any change outside of Quick Set, you should forget that it exists and not use it again. If you do, it can break your config, because it can't support all possible changes you do elsewhere.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
idanmikos
Sun Mar 29, 2020 12:36 am
Fact is that I didn't used Quick Set at all after configuring the router through IP-, Interfaces- and all other menus.
I have to mention that I have not used CLI, just winbox menus.
Sob
Sun Mar 29, 2020 1:14 am
Even better, then just ignore it completely and live happily ever after. :)
Users browsing this forum: Baidu [Spider], Google [Bot] and 78 guests
