andreas140265
(SOLVED) DISC Lite 5 died after upgrade, please help
Thu Apr 16, 2020 10:30 pm
I just upgraded my DISC Lite 5 to ROS v6.46.5.
The RB didnt reboot. I lost it. I have it now at my office.
When powered on it does not beep
The blue PWR led is on and the green USR led is on.
I cannot connect through ethernet. The ethernet link goes up and down every 3 seconds
I tried hard reset, holding the reset for 3 seconds after powering in order to load the backup boot loader. Nothing happened
Is there anything else I can do?
TIA
Andreas
Last edited by andreas140265 on Thu Apr 16, 2020 11:27 pm, edited 1 time in total.
andreas140265
Re: DISC Lite 5 died after upgrade, please help
Solved using NetInstall
macsrwe
Forum Veteran
Forum Veteran
Re: (SOLVED) DISC Lite 5 died after upgrade, please help
Fri Apr 17, 2020 12:01 am
Check the casing on that bad boy before returning it to service. We've had consistent case failures on these units, unlike any other MT unit we use.
Users browsing this forum: eguun and 103 guests
