Hi, experts!
I have a task to build a hotel network in a few secments and need some help. I think that here is the right place for my questions, becuse the main part of eqipment is by Mikrotik.
I plan to use CCR to manage all networks and cAP ac and wAP ac to provide wireless coverage. The other eqipment (switches) is manageable and it is from other manufacturer.
By my opinion I need by several networks for proper menagement:
1. Wired Staff network
2. Wireless Staff network
3. Wired Guest network
4. Wireless Guest network
5. CCTV network
6. TV network
7. Manage network
I have idea how to do that , but is it the right way?
1. I plan to create one Bridge to connect my switches to CCR.
2. On this Bridge I can create several VLAN's (1-7 networks)which will carry my traffic for different networks
3. To unite wireless networks 2 and 4 with wired networks 1 and 3 I have to create more two bridges (I need Wired and Wireless Staff networks to be one network and the same for Guest networks) into which I plan to import interfaces from CAPSMAN and VLAN 1 and VLAN 3.
example:
Bridge staff --> VLAN for wired staff network + AP wireless staff network by CAPSMAN
Bridge guest --> VLAN for wired guest network + AP wireless guest network by CAPSMAN
4. Then I have to gave addresses to bridges for Staff and Guest networks and for CCTV, TV and Manage VLAN's.
5. Create DHCP servers.
Is it right to import VLAN into two bridges for CAPSMAN or there is a other way to unite wired and wirelss networks?
and one more question:
How to build WiFi SSID's for 2,4 and 5 GHz - with one SSID or to separate band's. One SSID for 5 GHz band and the other for 2,4 GHz band?
At a later stage I want to manage all my networks by The Dude. Is any one have expirience with none Mikrotik eqipment and The Dude?
I hope that my English is understandable, because it is note my native.
Thank You
I hope your help
