weldox
SXT5ac managment VLAN
Wed May 13, 2020 4:39 pm
I have 2 Ubiquity M5 and 1 SXT5ac.
I have more VLANs passing thorugh these antennas. The main VLAN (that I use for managment) is VLAN 10 (10.10.10.0/24).
I can look at my 2 Ubiquity because they have an option:
Is there something of similar in SXT5ac? Or there is some workaround for it?
Or I Cannot "see" the SXT5ac.
Thank You very much!
Maurizio
floaty
Re: SXT5ac managment VLAN
Thu May 14, 2020 4:16 pm
just add a vlan-interface and choose your ethernet-interface as source-interface
in case you need this vlan on multiple ports, you have to interconnect the vlan-interface(s) with a bridge
... (there are more options if a hardware-switch in your plattform is involved ... but above option should work on every MTik-device ...
We know what happens to people who stay in the middle of the road. They get run over.
weldox
Tue May 19, 2020 5:08 pm
Thank You Floaty,
this is my config:
add fast-forward=no name=bridge1
set [ find default-name=ether1 ] speed=100Mbps
/interface vlan
add interface=ether1 name=vlan10 vlan-id=10
add exclude=dynamic name=discover
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk group-ciphers=\
tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik \
unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=xxxxxx \
wpa2-pre-shared-key=xxxxxxx
add authentication-types=wpa-psk,wpa2-psk eap-methods="" group-ciphers=\
tkip,aes-ccm management-protection=allowed mode=dynamic-keys name=\
"Security xxxxxxx" supplicant-identity="" unicast-ciphers=tkip,aes-ccm \
wpa-pre-shared-key=xxxxxxx wpa2-pre-shared-key=xxxxxxxx
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n channel-width=20/40mhz-Ce \
country=no_country_set disabled=no frequency-mode=manual-txpower mode=\
station-pseudobridge multicast-helper=disabled security-profile=\
"Security xxxxxx" ssid=xxxxxxxx vlan-id=10 wireless-protocol=802.11 \
wps-mode=disabled
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge1 interface=wlan1
add bridge=bridge1 hw=no interface=ether1
set discover-interface-list=discover
add interface=ether1 list=discover
add interface=bridge1 list=discover
add address=10.10.10.122/24 interface=bridge1 network=10.10.10.0
/ip dhcp-client
set servers=10.10.10.11,9.9.9.9
add distance=1 gateway=10.10.10.1
but I still cannot "ping" the SXT....
sindy
Tue May 19, 2020 5:45 pm
Two things. You cannot attach an /interface vlan to a member interface of a bridge (ether1 in your case), you must attach the /interface vlan to the bridge itself instead. It works "somehow, sometimes" the way you've configured it, but it's not reliable.
And second, you haven't attached any IP configuration to the /interface vlan (neither a static one nor a DHCP client), so no wonder you cannot access the SXT via that VLAN.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Users browsing this forum: Baidu [Spider], martinclaro, mbethers and 75 guests
