rradu92
QinQ trunk port
Wed May 20, 2020 1:44 pm
I have a scenario where I need to do qinq with multiple s-vlan and the same c-vlan in a trunk port.
The upstream provider sends me zone A with vlan 100 and zone B with vlan 200 as s-vlan and I need to send my c-vlans (31 and 32) to s-vlan 100 and s-vlan 200.
What I've tried is this, but I dont know if it is correct or what.
/interface vlan
add interface=sfp12 name=svlan100 vlan-id=100 # Service vlan 100
add interface=sfp12 name=svlan200 vlan-id=200 # Service vlan 200
add interface=svlan100 name=svlan100-cvlan31 vlan-id=31 # Client vlan 31 on service vlan 100
add interface=svlan100 name=svlan100-cvlan32 vlan-id=32 # Client vlan 32 on service vlan 100
add interface=svlan200 name=svlan200-cvlan31 vlan-id=31 # Client vlan 31 on service vlan 200
add interface=svlan200 name=svlan200-cvlan32 vlan-id=32 # Client vlan 32 on service vlan 200
add name=br-cvlan31 # Add bridge for client vlan 31
add name=br-cvlan32 # Add bridge for client vlan 32
add bridge=br-cvlan31 interface=svlan100-cvlan31 # Add client vlan 31 from service vlan 100 in the bridge br-cvlan31
add bridge=br-cvlan31 interface=svlan200-cvlan31  # Add client vlan 31 from service vlan 200 in the bridge br-cvlan31
add bridge=br-cvlan32 interface=svlan100-cvlan31  # Add client vlan 31 from service vlan 100 in the bridge br-cvlan32
add bridge=br-cvlan32 interface=svlan200-cvlan31  # Add client vlan 31 from service vlan 200 in the bridge br-cvlan32
Thanks in advance.
floaty
Re: QinQ trunk port
Wed May 20, 2020 9:09 pm
https://wiki.mikrotik.com/wiki/Manual:I ... LAN#Q-in-Q
not 100% posititve about ... but maybe the remote-device uses 802.1ad compliant tagging
then you need to set
use-service-tag = yes
We know what happens to people who stay in the middle of the road. They get run over.
floaty
Re: QinQ trunk port
Wed May 20, 2020 9:13 pm
in case your netflix is off duty ... surrogate:
https://www.youtube.com/watch?v=C46ISu_T2SE
starting 33:00
rradu92
Re: QinQ trunk port
Wed May 20, 2020 9:47 pm
The service vlan needs to be applied in the first vlan only (100 and 200) right?
sindy
Re: QinQ trunk port
Wed May 20, 2020 11:56 pm
s-vlans need 802.1ad (service) tagging (hence use-service-tag=yes), c-vlans need 802.1Q (customer) tagging, hence use-service-tag=no.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
floaty
Re: QinQ trunk port
Thu May 21, 2020 5:49 am
that may or may not be so ...
better you check that out by testing your configuration(s)
you should be suspicious, if two versions work : )
had QinQ never in production ... but earned all the the time mx'ed emotions, hearing production stories ....
rradu92
Re: QinQ trunk port
Thu May 21, 2020 8:57 am
I am using it in production but with cisco products and not with multiple s-vlans in the same trunk port, and just saw mikrotik is more "versatile" in this way and wanted to try it.because I really don't want to spend 456547765$ in a dedicated hardware just to be a middleware for this.
I will try it and will post here the results!
Thanks floaty
Users browsing this forum: alexanwar, Maggiore81, td32 and 139 guests
