paulct
hap ac2 arm issue
Thu May 21, 2020 10:46 am
Hi all
We use the hap ac2 quite extensively. We received a batch of 50 of them. Over 15 of them are "bricked". i.e cannot reset or netinstall them, usr light is solid and cannot mac telnet or see the router via lan or wifi.
We believe a new employee by mistake updated them using the arm-64bit version - this is the only thing we can think of.
Is this possible? Why is it possible? And is there a way to fix them?
bpwl
Long time Member
Long time Member
Re: hap ac2 arm issue
Thu May 21, 2020 11:20 am
Tried the backup bootloader ? https://wiki.mikrotik.com/wiki/Manual:RouterBOOT
..."Note: If you hold the button before applying power, backup RouterBOOT will be used in addition to all the above actions. To do the above actions without loading the backup loader, push the button right after applying power to the device."...
Users browsing this forum: Google [Bot], jebz, krisjanisj and 62 guests
