mobilecomm
RB2011 and RB4011 Issues
Thu May 21, 2020 5:53 pm
I have about 150 routers in our network, we have been experiencing in the last several months only, the router will stop passing data. All are ospf routed and then we can see them in the neighbors, but you can not access them via winbox or telnet. When you do get a mac telent to accept the user and password all it says is connected.. no other command lines to use. Any one else having this issues or seen other post on this problem.. All are NOT using same FW so I feel it is not FW related.
mutluit
Long time Member
Long time Member
Re: RB2011 and RB4011 Issues
Fri May 22, 2020 1:52 pm
Have you analyzed the logs? Any entries there?
If I were the admin of that network I would immediately initiate the security protocols. Something big seems to be fishy there.
If you post a simple drawing of your network topology with a short description then people can try to help.
I think I personally would throw out that OSPF completely and instead use static routing with some careful planning.
Users browsing this forum: Jacka, llubik, markos222, mtgate, pe1chl, roe1974, td32, thsun and 128 guests
