rafin
Forwarding traffic over IPSec
Thu May 21, 2020 7:02 pm
Hi
I need advice on how to configure Mikrotik to forward http and https request from R1 to R2 over IPsec so original client IP is visible on the www server on internal network of R2
Client. >>> R1 >> <IPSEC> R2 >>> WWW Server
Can someone share configuration details how to solve this?
Thanks,
Rafal
sindy
Re: Forwarding traffic over IPSec
Thu May 21, 2020 7:13 pm
The scenario you describe is nothing special, so the example in the manual should be sufficient? Or have I missed something in your description? Don't let the fact that the WAN interfaces in the example have private IPs, it works the same when they are public ones.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Users browsing this forum: alexanwar, Maggiore81, td32 and 127 guests
