inteq
3 routers in a row defective possible?
Mon Jun 01, 2020 11:55 am
So I have a FTTH location where internet drops completely between 10 seconds to 2 minutes, at random times, for 1-4 times a day.
Nothing in logs. No link downs on interface. Online UPS.
1st router: a RB4011. Because the router crashed couple of times, I thought those random internet dropouts were caused by it. Replaced it.
2nd router: a RB1100AHx4. New patch cable. Random dropouts continued. Bought a new one.
3rd router: a RB1100AHx4. New patch cable. Random dropouts continued.
Of course, ISP states they do not see anything wrong on ONT. Funny thing, after they first stated that there is nothing wrong with the connection and that the ONT has been online for ages, I just unplugged the fiber optic cable for 5 minutes, while keeping the ONT powered. Next time I opened a ticket, again, they stated the same thing. Go figure.
The question is: anyone had such a bad luck to have three defective routers in a row?
inteq
Re: 3 routers in a row defective possible?
Wed Jun 17, 2020 10:42 am
Sorry for bump, but this one is strange.
Installed the 2nd RB1100AHx4 (the one purchased after the 1st RB4011) in another location. Same provider, same FTTH tech.
2 weeks already and absolutely stable. No packet loss at all.
Setup a PC with intel nic in place of 3rd RB1100AHx4, in the problematic location, allowing just incoming icmp.
To simulate some traffic, every 10 minutes I scheduled a speedtest-cli.
2 days already and no packet loss at all, both in and out.
I am monitoring from 2 external locations with a tool that pings every 1 second with 1 second timeout. Not a single ping lost.
With both RB1100AHx4, in 2 days I would've had several hundred lost pings already.
I am really out of ideas on this one.
anav
Wed Jun 17, 2020 8:53 pm
I feel your pain.
I have similar issues withe an RB450Gx4 but perhaps more insidious over 2 years but I put it down to internet quirkiness for 2 years (now out of warranty).
Significant packet loss on traceroute to my both my ISPs gateways.
Win MTR shows losses
Traffic flow showed gaps that clearly showed NO tx and NO rcve and yet no log entries by router saying it was down.
I just completed a neinstall and I will post the trace route to the ISP gateway, and winmtr to google.ca results as well as the gap image from earlier testing, which shows one ISP with no Gap and the other with a huge gap.
No change! :-( Originally using 6.46.6 firmware, now uising 6.45.9 firmware - no difference!
https://imgur.com/1y5Gd9s
https://imgur.com/DYPJGH4
https://imgur.com/OHdK0RH
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
Sob
Wed Jun 17, 2020 9:34 pm
@anav: Your packet loss is misleading. It can be one long gap, like the one in your graph, yes. But let it run longer and it will be much better. ISP can also rate limit icmp. There's no way you could use connection with continuous 40 or 60% packet loss for years.
But I would tend to blame ISP, rather than router. Of course if it does that with two, it's suspicious. In any case, you already mentioned that you'll have another router, so just for fun, you can reset this one, give it minimal config (just two subnets and nothing else) and test it in your LAN, connect one computer behind it and let it copy something huge between it and device in other subnet (main LAN). And see if there will be similar gaps then.
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
inteq
Tue Jun 23, 2020 9:59 pm
To recap,
3 routerboards in a pure routing config, no NAT, no DHCP, no STP and even tested without a bridge: random packet loss lasting from couple of seconds to 1 minute.
Did a test with only one interface setup with a public IP, without routing or anything else plugged into it: random packet loss.
PC with intel network card. No routing, just a public IP setup on it. No packet loss at all.
Same PC with an additional intel network card and IPFire installed on it. Same setup as on the 3 routerboards. Routing without NAT, DHCP. No packet loss at all.
Sent one of the "problematic" routerboards to another location, but with NAT and DHCP enabled: no packet loss
A bit of a stretch but not setting up NAT/masquerade and just using routing can cause packet loss on RB1100AHx4?
A minimum config that still presents random packet loss. Only one interface setup. No NAT or anything else.
# jun/18/2020 21:53:08 by RouterOS 6.47
# software id = ASE2-1E2N
# model = RB1100x4
# serial number = 91D80A0C859E
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
set 12 default-vlan-id=0
set 13 default-vlan-id=0
set 14 default-vlan-id=0
set 15 default-vlan-id=0
add name=WAN
add name=Local
set discover-interface-list=Local
add interface=ether1 list=WAN
add interface=ether2 list=Local
add address=x.x.206.92/24 interface=ether1 network=x.x.206.0
set servers=1.1.1.1
add action=drop chain=input comment="Drop invalid " connection-state=invalid
add action=accept chain=input comment="Accept established and related" \
add action=accept chain=input comment="Accept icmp" protocol=icmp
add action=drop chain=input comment="Drop everything else" in-interface-list=\
    !Local
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
add distance=1 gateway=x.x.206.1
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Bucharest
/system logging
set 3 action=disk
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=Local
Dude outages:
hostclub
Tue Jun 23, 2020 11:55 pm
Sa mai zica careva ca Mikrotik nu e de cacao la faza asta....
I see that Mikrotik ARM CPU routers have issues, more than Tilera
Taking into account that the next generation of Mikrotik routers is ARM only.....I expect dark age for Mikrotik.
Sob
Wed Jun 24, 2020 2:06 am
You can try to disable the 'drop invalid' rule. It shouldn't be it, but since there's nothing else in your config...
sindy
Wed Jun 24, 2020 9:32 am
What does /interface ethernet print stats show on the problematic site? What happens if you place a stupid switch between the ISP gear and the 1100's WAN there (the stats only show Rx errors on the local interface, but cannot show Rx errors at the other end of the cable)? It sounds to me like an interface compatibility issue.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
inteq
Wed Jun 24, 2020 12:16 pm
@sob I have tried without the Drop invalid rule when @tippenring suggested here viewtopic.php?f=2&t=162627&p=801420#p801383. No change.
@sindy Will have to reinstall the RB1100AHx4 to be able to check /interface ethernet print stats but if I recall there were some RX errors logged seen under Winbox interface stats screen. Will test with a dumb switch and get back with info.
Another thing I wanted to mention is that I tested multiple ports, covering all 3 switches on the RB, to rule out a defective port as much as possible. Tested on ether1, 6 and 11.
Tried also lowering the CPU frequency from 1400 to 1200. No change.
Thank you all for replies.
nje431
Wed Jun 24, 2020 3:00 pm
I know this is a shot in the dark, but try disabling 1000/half under auto negotiate. The switch chip doesn't support that option, and if your ISP connection does...... I've disabled it in all ours, and they seem to be a lot more stable since then. Or maybe it's just my imagination.
sindy
Wed Jun 24, 2020 4:41 pm
I don't bother whether you use Winbox, WebFig or command line to check the Ethernet port statistics. But as long as you can see any Rx errors on Ethernet, it makes little sense to search for packet loss anywhere else. An Rx error means that the packet has been dropped as it arrived from the wire, big fat dot. There is no auto-correction on Ethernet - a packet with wrong CRC is simply not let through.
I did not have in mind a manufacturing issue on a single port (or switch chip) of the 1100. What I had in mind was a design issue - an electrical incompatibility between the 1100's ports and the port of the ISP's device or, no matter how odd it may seem, a mechanical incompatibility between the connectors on the patchcord and on one of the devices. I have got some factory-made patchcords (i.e. not DIY crimped) which do not work in my hAP ac lite but do in my PC. Other patchcords from the same purchase, differing only by cable color, work in both.
inteq
Thu Jun 25, 2020 4:43 am
Reinstalled the 3rd RB1100AHx4 tonight and did not have to wait longer than 2 hours for the first interruption. This time it lasted 2 minutes as reported by Dude.
So far used 4 different factory crimped ethernet cables and one cat 6 made by me.
/interface ethernet print stats taken after the 1st incident shows:
Stats after 11 hours uptime:
quackyo
Fri Jun 26, 2020 11:45 am
It seems quite probable that your ISP is having problems.
But just as a try. Disable dude monitoring of your router.
I have had some troubles with a RB1100AHx4 that seemed to be caused by monitoring by Dude.
sindy
Fri Jun 26, 2020 1:42 pm
So actually no Rx errors at the 1100 side at all. Unfortunately (or fortunately?), this still does not mean that there is no L1 problem, so if you can put a dumb switch between the 1100 and the ISP's port, do that. If it is still bad, keep the same dumb switch in place and connect, instead of the 1100, something that you have tested before to be working, to make sure that the dumb switch itself doesn't have an issue with the ISP gear.
inteq
Wed Jul 15, 2020 10:46 pm
This is getting a bit ridiculous.
I setup a 4th Mikrotik in the location, a RB1100AHx4 Dude Edition. Problem still persists.
I bought a P-Unlimited CHR license and setup RouterOS inside ESXi on a Supermicro server equipped with Intel X722 nics. Problem still persists.
Setup a Netwatch to call a traceroute script when ping fails on 3 targets and write a log file for each incident.
:execute {/tool traceroute 1.1.1.1 duration=5} file=("traceroute 1.1.1.1 from ".[/system identity get name] . " on " . [:pick [/system clock get time] 0 8] . " - " . [:pick [/system clock get date] 7 11] . [:pick [/system clock get date] 0 3] . [:pick [/system clock get date] 4 6])
Generates a filename: traceroute 1.1.1.1 from ros-esxi on 13:23:33 - 2020jul15.txt (could not figure out how to format the date so I have to download the file via ssh because of those : in time)
When the problem occurs, the content of the file is kinda empty, which is a bit weird:
I am starting to think the place is haunted.
sindy
Wed Jul 15, 2020 11:11 pm
No wonder if you took the task to connect the Poenari ruin to the internet :D
mkx
Thu Jul 16, 2020 8:35 am
Is this run on your border gateway? The first hop printed by traceroute is already router beyond the device running traceroute. If it's your border gateway running it, this means your link is failing. With that many different devices showing same symptoms it might actually be the line failing ... or ISP's gear. This is the reason I like to keep some ISP's gear at my place ... so that the line between ISP gear and my border gateway is well defined and easily replaceable (patch cord).
BR,
Metod
inteq
Thu Jul 16, 2020 8:59 am
No BGP.
Just ISP > ONT > Mikrotik.
Direct connected IP on one ether and a subnet on another ether.
The netwatch and script is run on Mikrotik
Simple diagram
mkx
Thu Jul 16, 2020 11:26 am
I mentioned border gateway (without P) ... in complex setups there might be multiple routers, but usually only one is border gatewa / router whic is demarcation point between your LAN and the rest of internet.
Anyhow, I'd say the problem is ONT or fibre between ONT and ISP ... specially so as you made a service break (by disconnecting optic connection) in controlled conditions and yet ISP claims everything was just fine ...
BR,
Metod
sindy
Thu Jul 16, 2020 11:47 am
The only argument against this assumption is that the test with nothing-to-do-with-RouterOS device as described in post #2 has shown no issues for two days, but I deem that adrgument quite strong.
@inteq, what happens if you just ping the gateway with arp-ping=yes and interval=100ms instead of using traceroute?
inteq
Thu Jul 16, 2020 11:55 am
Will setup with arp-ping=yes and interval=100ms and get back with details.
ping gatewayIP arp-ping=yes interface=ether1 interval=100ms
Thank you.
inteq
Re: 3 routers in a row defective possible?  [SOLVED]
Thu Dec 24, 2020 12:23 pm
Quick update
I disabled Dude notification for some time and just stopped thinking about it too much.
Beginning of December I decided to just disable The Dude because in my mind, the program had a lot of false positives. I just became numb to connection issues reported by The Dude.
Lo and behold, 2 weeks now already and the problem described in the 1st post of this topic went away. Confirmed from multiple external sources.
Somehow, it seems The Dude is causing massive/total packet loss for short duration.
Cannot really explain this and cannot really figure out how a monitoring program can cause such problems, but in my case it seems it did.
No more Dude for me.
jebz
Sat Dec 26, 2020 3:23 am
Quick update
I had troublesome monthly reboots on a RB1100AHx4de. Nothing was reported in the log except router rebooted without proper shutdown. I tried lots of changes but because it took so long it was difficult to make progress. In the end I disabled the DUDE and it didn't reboot in over 2 months. I changed to a brand new RB1100AHx4de with factory firmware 6.45.8 and manually recreated the config except I imported the DUDE database. I have currently 72days uptime with the new RB1100AHx4de and the DUDE on v6.45.9.
Does anyone think there could be code in the Dude that triggers a hardware fault in susceptible ARM routers?
inteq
Thu Jan 14, 2021 3:02 am
Enabled The Dude again for one week. Packet loss and problems started.
Disable again.No more packet loss.
I do not think it is related to ARM, because after trying 4 ARM Mikrotik routers I moved this particular location to a CHR unlimited and the same problem continues.
Funny thing is that RouterOS loses connectivity to a subnet behind it also with The Dude active, so I can rule out ISP problems.
Too bad it is not maintained and developed anymore. Nice piece of software not considering this problem.
quackyo
Thu Jan 14, 2021 11:50 am
Thanx for reporting, I have had problems with dude making my 1100 as well earlier, this means my find was correct.
Users browsing this forum: accarda, akakua, vikinggeek and 151 guests
