hotspotsolutions
How To: Connect to FreeRadius Server?
Thu Dec 16, 2004 1:51 pm
I am going to develop my own radius managment system usng either ASP, or ASP.Net.
I just need some pointers on what connection I can perform to the FreeRadius server?
Any Help is appreciated.
Thankyou
Joshua
Lord
Thu Dec 16, 2004 10:32 pm
Use /radius menu in Mikrotik and setup connection to FreeRadius
It use udp&tcp packets from Mikrotik to Radius server and sent AAA data.
Mikrotik fully compatible with FreeRadius and no compatible problem exist.
bjohns
Re: How To: Connect to FreeRadius Server?
Fri Dec 17, 2004 1:15 am
Thankyou
Joshua
For what reasons are you connecting to the FreeRADIUS server? Like if you want to manage it using an .asp script, then it is probably wiser to use a database backend and use that to store the configs.
hotspotsolutions
Database?
Fri Dec 17, 2004 3:58 am
I would love to simply use a database to manage users, but as far as I can see the only external managment of users that is available is a radius server?
wjw
Re: Database?
Fri Dec 17, 2004 12:10 pm
I started to build a management system using, freeradius with MySQL backend, and an NT Server running ASP and interfacing directly with the MySQL DB. Worked well, until I decided to try the Mikrotik Hotspot stuff ;)
Users browsing this forum: patrick7, sindy, skylark, SpartanX and 184 guests
