albart
Connect to VPN over 2 Internet connections
Sun Jun 14, 2020 3:27 pm
I need some help to setup the routing rules of this scenario because I don't get it.
This is my setup:
Addresses:
  • eth0, LAN, 10.0.0.0/24
  • PPPoE1, PPPoE with ISP 1 (connected in eth1), public ip address 1
  • PPPoE2, PPPoE with ISP 2 (connected in eth2), public ip address 2
  • ovpn-client pool, 192.168.10.0/24
Firewall:
  • input rule for open vpn port
  • nat masquerade on PPPoE2
  • nat masquerade on PPPoE1
  • mangle prerouting rule to mark traffic from 10.0.0.50 with isp1 mark
Routing:
  • 0.0.0.0/0 using PPPoE2
  • 0.0.0.0/0 using PPPoE1 if isp1 mark
The problem is:
  • When I connect to VPN using the public ip of ISP 2 I can go in and everything works except that I cannot connect to 10.0.0.50.
  • When I try to connect to VPN using the public ip of ISP 1, I cannot.
What I want is:
  • Keep default gateway using ISP 2
  • Keep outgoing traffic (not local or VPN) of 10.0.0.50 using ISP 1
  • Connect to VPN using either ISP 1 or ISP 2
  • Once connected to VPN, be able to connect to any host in VPN or LAN
I've been trying to mark traffic using mangle rules but I cannot get it. May be using routing policies? Any ideas, please?
Thanks in advance.
Regards.
albart
Re: Connect to VPN over 2 Internet connections  [SOLVED]
Sat Jun 20, 2020 3:35 pm
I got the solution.
Firewall:
  • Changed mangle prerouting rule to add routing mark to traffic from 10.0.0.50 and destination not 192.168.10.0/24 with isp1 routing mark
  • Added mangle input rule to add connection mark to traffic from PPPoE1 without connection mark with vpn1 connection mark
  • Added mangle ouput rule to add routing mark to traffic with connection mark vpn1 with isp1 routing mark
diego73
Tue Jun 22, 2021 9:25 pm
Hi albart!
can u help me with this post
viewtopic.php?f=13&t=176098
thanks!
Users browsing this forum: haung05, vingjfg and 78 guests
