bienios
PPTP VPN not established
Tue Jun 23, 2020 11:08 pm
Hello, I have an issue with VPN trying establish connection but the funny thing is it worked before now probably after couple updates it crashes. Updated to v6.47
Log says:
TCP Connection established from <ip_address>
I added both rules in Filter accepting 1723 and GRE.
I have nothing in "active connection".
Port PPTP enabled but can't set the port nr it highlighted on red when trying set the port.
What else should I consider?
sindy
Re: PPTP VPN not established
Sat Jun 27, 2020 4:33 pm
Consider posting an anonymized configuration export as per my automatic signature below.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Users browsing this forum: Pea and 67 guests
