ErfanDL
one IP from two different gateway
Mon Jun 29, 2020 9:43 pm
Hi friends. I have one IP from two different gateway. the IP is 172.20.8.1 from the 10.136.112.73 and 10.134.160.1 gateway. is it any way to change the 172.20.8.1 in to the two different IP ?
for example 172.20.8.1 from the 10.136.112.73 gateway convert to 172.20.8.5 and 172.20.8.1 from the 10.134.160.1 gateway convert to 172.20.8.6 ?
thanks.
sindy
Re: one IP from two different gateway
Mon Jun 29, 2020 10:26 pm
Are you talking about PPPoE uplinks?
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
ErfanDL
Mon Jun 29, 2020 10:32 pm
no these ip from our VOIP provider. we have two different voip number, one from 10.134.160.1 gateway with 172.20.8.1 registration IP and anothor is from 10.136.112.73 gateway with 172.20.8.1 registration IP.
Sent from my SM-A705FN using Tapatalk
sindy
Mon Jun 29, 2020 10:44 pm
So you mean "gateway" as VoIP gateway or "gateway" as a property of IP route? If VoIP gateway, you're not "getting IPs" from them in the sense of getting this assigned as your router's address by DHCP or PPP, but it means that they are expecting you to register from this address as source, and ignore registrations from any other address? Or it is reverse and 172.20.8.1 are the addresses of the registrar server, and you need to make sure that each of your two VoIP devices will be registering to the same remote IP (172.20.18.1) via a different route/WAN? Maybe a drawing will help...
ErfanDL
Mon Jun 29, 2020 10:54 pm
there is no dhcp or ppp. the voip working with static route cable connected.
VOIP1 >>> Mikrotik Gateway:10.136.112.73, IP:172.20.8.1 >>> Elastix Server
VOIP2 >>> Mikrotik Gateway:10.134.160.1, IP:172.20.8.1 >>> Elastix Server
the problem is VOIP1 only registered with 10.136.112.73 gateway from 172.20.8.1 IP and can't be registering with 10.134.160.1
sindy
Mon Jun 29, 2020 11:12 pm
I'm still lost. I need a drawing where the registrar servers, WAN links, and the VoIP equipment at your premises are shown, each with its address, like below:
registrar 1 - 1.1.1.1 --- WAN LINK X --- Mikrotik's WAN interface X - 3.3.3.3, Mikrotik's route to 1.1.1.1 via 3.3.3.4
registrar 2 - 2.2.2.2 --- WAN LINK Y --- Mikrotik's WAN interface Y - 4.4.4.4, Mikrotik's route to 2.2.2.2 via 4.4.4.3
local site VoIP equipment - 5.5.5.5 --- LAN interface A - 5.5.5.6
Because I still did not understand whether the 172.20.8.1 is at your premises or at the ISP/VoIP operator side.
Users browsing this forum: alber, cedie, DarkNate, Google [Bot], sakalsk, sindy and 65 guests
