Hi all
i need to design solution with "multilink" for WAN connection and also i need a GRE encapsulation.
I buy two routers CCR1036-8G-2S+EM for that because all track i need to have 10Gb/s.
i connect like that
host ---- router ---- router ---host
this connection is for lab but on production there wiil be two ISP between the routers. so .. on my lab i set two adresses on WAN connection.
on start (on clear configuration) i run iperf from host to host (only one direction) i have 9,6 Gb/s
then i add GRE tunnel(sinle) iperf result 9,5Gb/s
but when i add second adresses on WAN connection, add second gre tunnel, and define ECMP (with PCC on mangle firewall) i have a lot of packet retransmission and 1,3Gb/s. is this an performance problem ??? (as they said on their webpage this is the fastest router in portfolio so where is the problem ? )
[ 4] local 172.31.19.50 port 44458 connected to 172.31.0.50 port 5201
[ ID] Interval Transfer Bandwidth Retr Cwnd
[ 4] 0.00-1.00 sec 154 MBytes 1.29 Gbits/sec 462 266 KBytes
[ 4] 1.00-2.00 sec 167 MBytes 1.40 Gbits/sec 657 273 KBytes
[ 4] 2.00-3.00 sec 175 MBytes 1.46 Gbits/sec 858 287 KBytes
[ 4] 3.00-4.00 sec 167 MBytes 1.40 Gbits/sec 1103 276 KBytes
[ 4] 4.00-5.00 sec 166 MBytes 1.39 Gbits/sec 1017 262 KBytes
[ 4] 5.00-6.00 sec 170 MBytes 1.42 Gbits/sec 904 270 KBytes
[ 4] 6.00-7.00 sec 176 MBytes 1.47 Gbits/sec 1560 216 KBytes
[ 4] 7.00-8.01 sec 175 MBytes 1.46 Gbits/sec 695 284 KBytes
[ 4] 8.01-9.00 sec 177 MBytes 1.49 Gbits/sec 1000 284 KBytes
[ 4] 9.00-10.00 sec 170 MBytes 1.43 Gbits/sec 902 189 KBytes
[ 4] 10.00-11.00 sec 164 MBytes 1.38 Gbits/sec 926 197 KBytes
[ 4] 11.00-12.00 sec 167 MBytes 1.40 Gbits/sec 540 279 KBytes
^C[ 4] 12.00-12.84 sec 150 MBytes 1.50 Gbits/sec 662 279 KBytes
