MUM Europe 2020
bohamilton
Web Proxy Problem - Only with Hotmail
Sat Dec 18, 2004 5:36 am
Im running v2.8.11 w/ webproxy, One week ago hotmail will return a blank page for all users. This is the only site that has a problem. A fellow wisp has the same setup that I have but has no problem with hotmail. Has anyone had this trouble? cgi-bin \? is blocked.
Bo
mag
Re: Web Proxy Problem - Only with Hotmail
Sat Dec 18, 2004 10:03 am
not with hotmail, but some other pages. by deactivating the transparent proxy dst-nat rules the pages load without problem. (i am using transparent mode)
did you try 2.8.21 (afaik there's a newer squid in)?
what means "cgi-bin \? is blocked", did you change the default cache rule?
regards,
   matthias
bohamilton
Mon Dec 20, 2004 9:16 am
Thanks for the reply matthias
>what means "cgi-bin \? is blocked", did you change the default cache >rule?
This is stating that "do not cache any cgi web pages" as in MSN
Hit me off list and I will let ya in to take a look if ya want
bo@networksltd.net
maximan
Trainer
Trainer
Mon Dec 20, 2004 3:29 pm
Just pust this
ip firewall dst-nat>add src-address=LanIpAddress/24 dst-address=65.54.246.0/24 action=accept
With this you don't use the webproxy for hotmail's ip.
I try this and resolved
Maximiliano
Intercity srl
maximan
Trainer
Trainer
Tue Dec 21, 2004 6:45 pm
But sometime still without work'??
if i disabled the webproxy the are not problem???
some workarround??
M.
mag
Wed Dec 22, 2004 9:37 am
(sorry i was off for a few days)
some problems using the proxy turned out to be caused by the upstream isp, they never said what it was, but it was fixed. i would guess some faulty traffic shaping.
i found it by testing the same router/config with another isp.
regards.
   matthias
nazemg
Wed Dec 22, 2004 3:01 pm
Having the same problem with proxy and hotmail only on one of the proxy boxes we use and its on 2.8.21.
nathan@iridis
Wed Dec 22, 2004 5:22 pm
The strange thing is this problem only affects IE users, Mozilla FireBird works perfectly still. Any ideas anyone/mikrotik ?
Cameron Earnshaw
Thu Dec 23, 2004 7:21 am
Same problem here with 2.8.19. Only with Hotmail, and it started just in the last few days. I have the default "cgi-bin \?" rule in place. I have turned the proxy off until I can find a solution.
maximan
Trainer
Trainer
Thu Dec 23, 2004 1:25 pm
There is a bug with transparent proxy +ie +hotmail
This threat have a workaround
http://www.mikrotik.com/forum/viewtopic.php?t=1683
Maxi
nazemg
Fri Dec 24, 2004 1:40 am
Below rule solved the problem for us
/ ip firewall dst-nat
add dst-address=64.4.0.0/18 action=accept comment="hotmail" disabled=no
(place above before redirect tule)
NB please note we only had the problem with one proxy server that had another box as parent proxy.
Users browsing this forum: nwmurphy and 100 guests
