If you deploy 3 Audience units A-B-C where B is physically in the middle, but A is the main router, how do you get C to sync to B not A? It doesn't seem to matter if you press the sync button on B, we still see C sync to A which is much farther away. Previous forum posts my Normis in 2019 led me to believe you could dictate the sync topology based on which unit you pressed the sync button to initiate sync, but that doesn't seem to be the case, probably I misunderstood.
Is there a trick to this, or is it just not possible? Is it possible but requires manual configuration changes?
The configuration that is automatically generated on the CAPs has wlan3 as station bridge and virtual wlan4 as ap bridge, all with the same SSID as wlan3 on the main unit. And every unit bridges all the ethernet and wlan interfaces together. I can't find anything different in the config on B and C that would tell C it should sync to A even though B has a much better signal.
We definitely run into houses where A, B and C are on different floors or spread out in a big house, but the Internet connection cannot easily be wired to the middle unit B. So we cannot use a star configuration, it has to be a daisy-chain.
