u2615
ACL rules on CRS-354-48G-4S+2Q+
Wed Aug 19, 2020 9:46 pm
Hi all,
I played around with switch rule ACLs and 802.1X and found out that I don't get the ACLs working properly.
My dynamic rules:
/interface ethernet switch rule> print
 0  D ;;; dot1x dynamic
      switch=switch1 ports=ether26
      src-mac-address=00:24:54:XX:XX:XX/FF:FF:FF:FF:FF:FF mac-protocol=ipv6
      copy-to-cpu=no redirect-to-cpu=no mirror=no
 1  D ;;; dot1x dynamic
      dst-address=10.0.0.0/8 copy-to-cpu=no redirect-to-cpu=no mirror=no
 2  D ;;; dot1x dynamic
      src-mac-address=00:24:54:XX:XX:XX/FF:FF:FF:FF:FF:FF copy-to-cpu=no
      redirect-to-cpu=no mirror=no new-dst-ports=""
When I understand this correctly, I shouldn't be able to ping 8.8.8.8, but it works.
Then I tried static rules:
 0 X  switch=switch1 ports=ether26 copy-to-cpu=no redirect-to-cpu=no mirror=no
      new-dst-ports=""
 1    switch=switch1 ports=ether26 mac-protocol=ip copy-to-cpu=no
With rule 0 disabled and only rule 1 active all IPv4 traffic should be blocked, but isn't. Rule 0 works and blocks everything.
I also tried to swap bytes (0x0800 -> 0x0008) but without success (like mentioned here viewtopic.php?f=2&t=162887&p=802962).
This is on a CRS-354-48G-4S+2Q+ with RouterOS 6.47.2.
What could be wrong?
ploquets
Re: ACL rules on CRS-354-48G-4S+2Q+
Sun Oct 18, 2020 6:49 am
Users browsing this forum: Baidu [Spider], herikoerniawan, jakclyndpozo and 137 guests
