Clicking IP>Hotspot>Hosts tab resets the hotspot active list, disconnects all clients and creates a problem with Queues:
failed to add simple queue for interface bridge-hotspot: already have such name (6)
No one can login unless they are bypassed.
Only solution I've found so far is to disable rate limit on hotspot user profile temporarily until a proper solution is found.
Even after doing that, if you navigate to IP>Hotspot>hosts again, hotspot resets.
Can anyone else confirm this?
Don't try it in a production environment.
