iginooo
Two routerboard connection
Wed Oct 07, 2020 12:02 am
I have a one small problem with this situation: I have two router boards, first ist configure with dhcp 192.168.77.0/24 (port 1 is WAN1 for ISP, port 5 is WAN 2 for second routerbord. Second routerboard I have configured for dhcp 192.168.88.0/24 (port 1 is second ISP) I dont use firewall. Port 5 (first board) is connected to port 4 (second board). In board one I have connected via dhcp one device, which must comunicated with another device in second board. Everything runnning corretly, but problem is in IP. Device in board one has IP - 192.168.77.250, port 5 in board one has ip .88.200 (IP from second board DHCP) - and this is a problem. When I trying connect to device in second board with IP .77.250 I connect, but IP which I see in device is IP .88.200, no .77.250. I want direct connection with this two devices. It is possible?
Thank you very much.
Lelik200
Re: Two routerboard connection
Tue Oct 20, 2020 8:22 pm
Hello!
On first board you need to disable NAT or masquarade rules for output port 5 if it exist.
On second board you need to add route to 192.168.77.0/24 network:
/ip route add dst-address=192.168.77.0/24 gateway=192.168.88.200
Users browsing this forum: jvidaurre, sindy and 148 guests
