FIPTech
Cannot create Rules and VLAN in switch filter - Winbox 3.27 - Router OS 6.47.4 on RB3011UiAS
Thu Oct 15, 2020 5:01 pm
Since upgrade to Router OS 6.47.4 from 6.43.2, i'm not able to create switch rules and switch vlans with Winbox 3.27. (RB3011UiAS).
I did upgrade to from Winbox 3.18 to Wonbox 3.27 at the same time.
The rules or vlans are added but appear colored in red inside Winbox. If i use Winbox 3.18, then adding rules work again.
If i try to add it through the console it's working.
And i suspect that some rules are not working correctly anymore since the upgrade as i have now some IPv4 leaking on IPv6 interfaces. This leaking was filtered here before.
I'm not sure that this last problem does come from the switch filter nevertheless, because this traffic should be catched before in the bridge filter. but it is not.
anav
Re: Cannot create Rules and VLAN in switch filter - Winbox 3.27 - Router OS 6.47.4 on RB3011UiAS
Thu Oct 15, 2020 10:01 pm
Please post your config
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
FIPTech
Fri Oct 16, 2020 12:45 am
The problem is related to Winbox 3.27 as there is no problem with Winbox 3.18
anav
Fri Oct 16, 2020 2:37 am
Well then report it with a ticket and use 3.18.
Users browsing this forum: Baidu [Spider], Yahoo [Bot] and 101 guests
