karthikpenta
PHP APi Connection
Fri Oct 16, 2020 1:49 pm
Hi Guys,
I am using the Mikrotik API PHP (RouterOS PHP API class v1.6) to connect and read the queue types & its Rates. However, the API connect function is return false.
But works fine with WINBOX using the same login credentials.
I can able to see the connection attempt as 'login failure for user xxxx from xxx.xxx.xxx.xx via api' at WINBOX logs.
Enabled api with port on 'IP services list'.
Sample code:
require('routeros_api.class.php');
$API = new RouterosAPI();
if ($API->connect('IP', 'USERNAME', 'PASSWORD')) {
die('connnect');
When i run the code, it says 'invalid user name or password - Unable to connect to RouterOS ' . But the same login credentials works fine with WINBOX
Any thoughts?
mrz
Re: PHP APi Connection
Fri Oct 16, 2020 2:00 pm
https://wiki.mikrotik.com/wiki/Manual:API#Initial_login
see notes in login process post-v6.43
karthikpenta
Fri Oct 16, 2020 2:29 pm
This is my connection function code from routeros_api.class.php
function connect($ip, $login, $password)
for ($ATTEMPT = 1; $ATTEMPT <= $this->attempts; $ATTEMPT++) {
$this->connected = false;
$this->debug('Connection attempt #' . $ATTEMPT . ' to ' . $ip . ':' . $this->port . '...');
$this->socket = @fsockopen($ip, $this->port, $this->error_no, $this->error_str, $this->timeout);
if ($this->socket) {
socket_set_timeout($this->socket, $this->timeout);
$this->write('/login');
$RESPONSE = $this->read(false);
if ($RESPONSE[0] == '!done') {
$MATCHES = array();
if (preg_match_all('/[^=]+/i', $RESPONSE[1], $MATCHES)) {
if ($MATCHES[0][0] == 'ret' && strlen($MATCHES[0][1]) == 32) {
$this->write('/login', false);
$this->write('=name=' . $login, false);
$this->write('=response=00' . md5(chr(0) . $password . pack('H*', $MATCHES[0][1])));
$this->connected = true;
break;
fclose($this->socket);
sleep($this->delay);
if ($this->connected)
$this->debug('Connected...');
else
$this->debug('Error...');
return $this->connected;
How can i modify it to Work?
mrz
Fri Oct 16, 2020 2:31 pm
as described in the link I provided.
send /login =name= =password= in first message
karthikpenta
Fri Oct 16, 2020 2:37 pm
Thanks for your guidance.
Modified the code like this. Still same error. Did I miss something?
$this->write('=password=' . $password, false);
$MATCHES = array();
break;
else
mrz
Fri Oct 16, 2020 2:54 pm
there is no need to send /login again with md5 hash
Sob
Fri Oct 16, 2020 3:19 pm
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
karthikpenta
Fri Oct 16, 2020 3:20 pm
Thank you.. but Still the same error. $RESPONSE = $this->read(false) returns just an empty array. Can you please the code now
$MATCHES = array();
break;
else
karthikpenta
Fri Oct 16, 2020 3:24 pm
Thanks for the class file. But still the same issue.. I think the prob is not from class file. Look like something else
karthikpenta
Fri Oct 16, 2020 3:46 pm
Issue maybe from any ip blocking or any firewall settings? Why my connection is refusing by server?
Any ideas?
Sob
Fri Oct 16, 2020 3:50 pm
If you can see connection attempt in router's log, then it clearly passed through firewall, otherwise it wouldn't be there at all.
karthikpenta
Fri Oct 16, 2020 4:07 pm
Yes you are right! I don't know whats the exact issue.. Can you please help me to check it?
Sob
Fri Oct 16, 2020 4:25 pm
The class I linked to works fine for me, so I don't know what can be wrong. Add some more debug output in connect(), just simple "echo" is fine, to see what exactly fails. Dumping $RESPONSE is good start.
karthikpenta
Fri Oct 16, 2020 4:32 pm
Ok sure.
Result of : $RESPONSE = $this->read(false) :
Array
[0] => !trap
[1] => =message=std failure: not allowed (9)
[2] => !done
Sob
Fri Oct 16, 2020 5:06 pm
I don't know what that is, but maybe some problem with permissions for used username?
karthikpenta
Sat Oct 17, 2020 7:13 am
Ohh ok.. I will check and get back to you.
Users browsing this forum: No registered users and 104 guests
