msatter
How can I make Mikrotik help pages more readable?
Fri Oct 16, 2020 2:43 pm
Mikrotik is switching from the Wiki to the Help pages and I can't read it good brcause the rext area is very narrow. Examples and tables have to be scrolled horizontal all the time.
I have to tap the two vertical bars in the left column and directly after that the book icon that is then displayed. On a tablet hitting those icons is very tricky.
Is there a way to make it easier to read the Mikrotik help pages on a tablet or phone?
One RB4011 (cooled) and a RB760iGS (hEX S) in series. The 4011 Does PPPoE/IKEv2.
The cooler: viewtopic.php?f=3&t=138613&start=300#p799879
Running:
RouterOS 6.48beta35 / Winbox 3.27 64bits / MikroTik APP 1.3.15
normis
Re: How can I make Mikrotik help pages more readable?
Fri Oct 16, 2020 2:52 pm
You are right, it does resize badly on small displays. We will work on that.
Users browsing this forum: Google [Bot], MulderSk and 83 guests
