kenttec
join 2 ports without dhcp
Fri Oct 16, 2020 6:42 pm
I have looked at many items on this forum, but nothing quite gives me what I need. I have tried everything within my skillset but am now stuck.
This is what I am trying to achieve.
port1 broadband
port 2-4 Lan on ip 192.168.2.0/24 with DHCP
port 5 another network 192.168.1.0/24 which has its own dhcp.
be able to see each network, ie 255.255.0.0
first I tried just using the standard bridge and joining all 5 together, but this just sent the DHCP form each network back to the other network.
second I tried giving each port 2-5 and 5 a static IP 192.168.1.253 and 192.168.2.253, then linking them together with a firwall filter rule, but all I have done is block the connections altogether.
Any pointers would be apreciated.
Geoff.
tdw
Long time Member
Long time Member
Re: join 2 ports without dhcp
Fri Oct 16, 2020 10:19 pm
If you have a working setup with ether1 as WAN and ether2-5 in a bridge as LAN all you should have to do is remove ether5 from the bridge and add an IP address to that port.
The mikrotik will route traffic between the two subnets, subject to firewall rules, but you will have to make changes to devices on the 192.168.1.0/24 subnet in order for traffic to be returned. This can be static routes on each device, or a static route on the other router for the 192.168.1.0/24 subnet.
A diagram of exactly what you are trying to achieve would likely be more useful than attempting to infer everything from a brief description.
anav
Sat Oct 17, 2020 2:16 am
I would use VLANS to separate the subnets and all tied to one bridge.
That way all the interfaces can be on the bridge (except ether1 to your modem) and then you can run vlans (subnets) over any interface you wish (max flex).
Finally use Firewall forward chain rules to create any cross talk you wish to permit, for example all the users in vlan10, are allowed access to the shared Printer IP address on VLAN 20, or
vlan 10 users (3 of them by firewall address list) are allowed to access a server on vlan20 and so on.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
Users browsing this forum: ahtoh, Majestic-12 [Bot] and 134 guests
