kpleung
Port forward not working
Fri Oct 16, 2020 7:39 pm
Hello Everyone,
I want to make a simple port forward on the router, I pretty sure the similar configure worked on my other Mikrotik router (other location). But I have no idea why this setting doesn't work.
It got this message from the log:
firewall,info dstnat: in:wan1 out:(unknown 0), src-mac xx:xx:xx:xx:xx:xx, proto TCP (SYN), xxx.xxx.xxx.xxx:58184->yyy.yyy.yyy.yyy:443, len 52
I googled about this message, but seem no one got solution.
Below is the /export compact result
# oct/17/2020 00:18:14 by RouterOS 6.47.4
# software id = 7K81-9IBF
# model = RB4011iGS+
# serial number = xxxxxxxxxxxxx
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=wan1
/interface l2tp-client
add allow-fast-path=yes connect-to=xxxxxxxxxxx disabled=no ipsec-secret=xxxxxxx name=xxxxxx password=xxxxxxxx use-ipsec=yes user=xxxxxxx
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=192.168.14.11-192.168.14.230
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
/ppp profile
add name=xxxxxxx
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add comment=defconf interface=wan1 list=WAN
add address=192.168.14.1/24 comment=defconf interface=bridge network=192.168.14.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1d
/ip dhcp-client
add comment=defconf disabled=no interface=wan1
/ip dhcp-server lease
add address=192.168.14.xx mac-address=XX:XX:XX:XX:XX:XX server=defconf
add address=192.168.14.0/24 comment=defconf dns-server=192.168.14.1,1.1.1.1,8.8.8.8 gateway=192.168.14.1
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
/ip dns static
add address=192.168.14.1 comment=defconf name=router.lan
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=forward comment="cust: accept 80,443 from WAN" dst-port=80,443 in-interface=wan1 protocol=tcp
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall mangle
add action=accept chain=prerouting disabled=yes dst-address=192.168.14.209 dst-port=443 log=yes protocol=tcp
add action=accept chain=postrouting disabled=yes dst-address=192.168.14.209 dst-port=443 log=yes protocol=tcp
add action=dst-nat chain=dstnat comment="cust: dstnat 443 from WAN" dst-address=YY.YY.YY.YY dst-port=443 log=yes protocol=tcp to-addresses=192.168.14.209
add action=masquerade chain=srcnat comment="LAN to Server" disabled=yes dst-address=192.168.19.0/24 src-address=192.168.19.0/24
add action=masquerade chain=srcnat out-interface=xxxx-l2tp
add distance=1 dst-address=eee.eee.eee.eee/ee gateway=xxxx-l2tp
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
/system clock
set time-zone-name=Asia/Hong_Kong
/system identity
set name=RB4011
/tool mac-server
/tool mac-server mac-winbox
Sob
Re: Port forward not working  [SOLVED]
Fri Oct 16, 2020 10:28 pm
Dstnat rule is fine and if it logs something, it means that it's reachable from outside. You are testing it from outside, right?
Check target device (192.168.14.209):
- is there something listening in port 443?
- are connections to port 443 from anywhere allowed in device's firewall?
- does the device have this router as its default gateway?
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
anav
Sat Oct 17, 2020 2:11 am
(1) What is the purpose of this rule in the forward chain??
It looks like a destination nat type rule in the wrong place?
(2) The first rule ........... is YY.YY.YY your fixed WANIP address (or is your WANIP dynamic??)
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
kpleung
Sat Oct 17, 2020 8:35 am
Thanks Sob, you reminded me to check the default gateway of the target device, and yes, the problem was there, it works after I fix the default gw, Thanks a lot.
kpleung
Sat Oct 17, 2020 8:36 am
Thanks anav, your comment clarified me that I don't need a filter rules to make the port forward work, thanks
Users browsing this forum: Baidu [Spider], Bing [Bot], MulderSk and 68 guests
