Askey307
PPPoE and L2TP Connection/Routing Issue
Sat Oct 17, 2020 6:58 pm
Hi guys
Having a little bit of an issue. Cisco got damaged and had to replace it with RB2011 laying around. My issue I'm having is that I have to connect to office network via L2TP.
My main internet WAN connection is via PPPoE. Up to the Mikrotik, everything works and I can ping local ranges at the office etc.
Issue I'm having is my client device such as my workstation and other client device cannot see these ranges or ping. See picture attached of what I mean.
Assistance will be appreciated.
sindy
Re: PPPoE and L2TP Connection/Routing Issue
Sat Oct 17, 2020 7:47 pm
The quality of an answer depends on the quality of the question. So to get any useful advice, post your configuration in text form, following the anonymisation hint in my automatic signature right below. Screenshots are useless for any analysis, and yours in particular just show that it doesn't work, nothing else.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Askey307
Sat Oct 17, 2020 7:59 pm
I've added the config. The 192.168.0.0/24 range randomly started working on client devices such as 192.168.0.102 in the office. The 192.168.80.0/24 ranges till not reachable by client devices. I'm using the default config and firewall of MT for now. Let me know what else you require.
add admin-mac=E4:8D:8C:0A:FF:0A auto-mac=no comment=defconf name=bridge
set [ find default-name=sfp1 ] disabled=yes
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 user=\
   xxxxxxxxx@xxxxxxx.co
/interface l2tp-client
add connect-to=mail.xxxxx.com disabled=no name=l2tp-out1 user=conrad
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=MikroTik-0AFF13 station-roaming=enabled wireless-protocol=\
    802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.10.200-192.168.10.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=sfp1
add list=WAN
add address=192.168.10.1/24 comment=defconf interface=ether2 network=\
    192.168.10.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.10.254 client-id=1:54:be:f7:38:e4:c0 mac-address=\
    54:BE:F7:38:E4:C0 server=defconf
add address=192.168.10.251 client-id=1:b0:be:76:22:9d:42 mac-address=\
    B0:BE:76:22:9D:42 server=defconf
add address=192.168.10.0/24 comment=defconf gateway=192.168.10.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.10.1 comment=defconf name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    ipsec-policy=out,none
add distance=1 dst-address=192.168.0.0/24 gateway=l2tp-out1 pref-src=\
    192.168.10.1
add distance=1 dst-address=192.168.80.0/24 gateway=l2tp-out1 pref-src=\
    192.168.10.1
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add type=external
add interface=pppoe-out1 type=external
/lcd interface pages
set 0 interfaces=wlan1
/system clock
set time-zone-name=Africa/Johannesburg
/tool mac-server
/tool mac-server mac-winbox
sindy
Re: PPPoE and L2TP Connection/Routing Issue  [SOLVED]
Sat Oct 17, 2020 8:14 pm
It's strange, as everything looks fine in your configuration. The routes are there, the masquerade rule is there (it could be more selective but it doesn't cause any trouble as-is given the rest of the configuration). So try pinging something in the 192.168.80.0/24 range that you know to respond, from a client device in 192.168.10.0/24, and run
/tool sniffer quick interface=l2tp-out1 ip-protocol=icmp ip-address=192.168.80.x
(change the x accordingly). What can you see?
There is one minor mistake, the own address of the Mikrotik, 192.168.10.1/24, should not be attached to ether2 but to bridge, but it doesn't explain the issue. To fix that part, use
/ip address set [find interface=ether2] interface=bridge
Askey307
Sat Oct 17, 2020 8:25 pm
I fixed the "ether2" issue. Thank you for noticing. Yeah, I can ping the main router over in the one NDC on 80.1.
I can even open the NMS on 80.3 without an issue but cannot ping it. The 80 range is a VSAT 550ms+ range. Still don't explain it.
The other ranges just started pinging and became accessible randomly without intervention half an hour after creating this post.
Sniffer also get response from 80.3
Think I'm getting high.
sindy
Sat Oct 17, 2020 8:32 pm
Do I read you right that the sniffer shows an ICMP response from the 80.3 but the client cannot see it? I.e. the response doesn't make it through the Mikrotik to the client?
Askey307
Sat Oct 17, 2020 8:39 pm
Yeah you did read that right. I know you don't like screenshots, but see attached. To the right is the client pc that can't ping it but can access the NMS. The screenshot also shows the response of the sniffer.
Askey307
Sat Oct 17, 2020 8:53 pm
Aaaaand there it started pinging randomly without intervention....
Am I missing something about Mikrotik's dynamic process'?
sindy
Sat Oct 17, 2020 9:01 pm
The sniffer says the response from the 80.3 arrives 40-60 ms after the request is sent in the opposite direction. But as you mention there's a VSAT link in the path, 40-60 ms is mission impossible, so could it actually be 1040-1060 ms (i.e. response to request N arriving after request N+1)? In that case, pinging from the Windows with -w 1500 might give better results?
Askey307
Mon Oct 19, 2020 12:59 pm
Everything works great now. However, did found something Saturday evening after a lot of reading that caused this "anomaly" even though I was a bit skeptical about it, it seem though that it was the route table cache in the background. Did test it yesterday quite a bit by disabling "route-cache" and all routes establish instantly but then losing the fast path functionality and when enabling it as it is on default, it "hangs" the route for a time again before responding. Can't say for sure that this was the issue.
Users browsing this forum: Bing [Bot], Google [Bot] and 127 guests
