What does the advantage put the router before firewall and internet? Or what is the purpose to do this setup.
thx
Be careful with that router ! There is no security if you do not process the logs and alerts. (Ethical hackers first compromise the upfront router, and change the DNS flow)Router will always be sufficiently protected from the internet - with a few crude rules you can block everything.
For that matter, internet got hacked when DARPA let in businesses back in early 1990's.Just imagine if your ISP gets hacked ....
How can you prove we are not in a simulation???
Good point, but that applies to every device, no matter if it is in front or behind the firewall.Be careful with that router ! There is no security if you do not process the logs and alerts. (Ethical hackers first compromise the upfront router, and change the DNS flow)
Not that hard to imagine. It won't be any different than every other MITM attack. Thats why we have encryption almost everywhere nowadays, right?Just imagine if your ISP gets hacked..
