pauljr
rb133c beta 3.9
Fri Jun 29, 2007 12:16 am
I have tried to upgrade 4, rb133's to beta 3.09 to take advantage of psuedo-bridge. I have tried doing it several different ways. The latest attempt I upgraded from 2.9.43 and uninstalled every package except systema and wireless like some previous post suggested. After the upgrade I was able to get in with winbox but cpu was at 100% and stayed that way until I disabled the wireless package and rebooted. Now with just the system package the cpu is 2-3%.
Any ideas? I'm using the atheros WLM54G wireless card.
I have even tried taking the card out and enabling wireless package and I have the same problem.
Thanks for any advise.
Paul
GotNet
Re: rb133c beta 3.9
Fri Jun 29, 2007 4:09 am
I've never had an upgrade from 2.9.x to beta3 work. Best (why?) is to format nand then netinstall beta3 fresh then setup even if the configuration is the same.
pauljr
Re: rb133c beta 3.9
Fri Jun 29, 2007 4:31 am
I tried that on 3 of them but netinstall never works. When I do it over ethernet is says network error and when I do it over serial it says someing like "invalid upgrade file id" after it's finished uploading. I'm stuck on those 3 without any os on them.
oz_gr
Re: rb133c beta 3.9
Sun Jul 15, 2007 6:12 pm
have you solved the problem on mentioned 3 rb's ??
pauljr
Re: rb133c beta 3.9
Mon Jul 16, 2007 5:24 pm
Support @ mtik suggested I wait untile 3.10 was out and I haven't yet had chance to try them. So I haven't yet resolved this issue but I haven't had a chance to try 3.10. I'll try to do this test today. I will post my results.
Users browsing this forum: Bing [Bot], freddi, Google Feedfetcher, JohnTRIVOLTA, mikeeg02, takeshisan and 51 guests
