I want to do a secure VPN for my home network.
It's important to notice that my router already have L2TP client interface with another Network Access Provider by BGP.
I'm stuck on the following problem :
LOGS
Code: Select all
ipsec,debug add payload of len 52, next type 13
ipsec,debug add payload of len 16, next type 13
ipsec,debug add payload of len 20, next type 0
ipsec,debug 148 bytes from 45.13.94.170[500] to 77.204.176.9[1525]
ipsec,debug 1 times of 148 bytes message will be sent to 77.204.176.9[1525]
ipsec sent phase1 packet 45.13.94.170[500]<=>77.204.176.9[1525] 1ddabfc337ad5334:27ab8ad322357ad2
ipsec,debug ===== received 724 bytes from 77.204.176.9[1525] to 45.13.94.170[500]
ipsec,info the packet is retransmitted by 77.204.176.9[1525].
ipsec resent phase1 packet 45.13.94.170[500]<=>77.204.176.9[1525] 1ddabfc337ad5334:27ab8ad322357ad2
ipsec,debug deleted the retransmission packet to 77.204.176.9[1525].
ipsec,debug 77.204.176.9 malformed cookie received. it has to be as the initiator. 45.13.94.170[500]<=>77.204.176.9[1525] 1ddabfc337ad5334:27ab8ad322357ad2
l2tp,info first L2TP UDP packet received from 77.204.176.9
l2tp,debug tunnel 38 entering state: wait-ctl-conn
l2tp,debug tunnel 38 entering state: dead
ipsec,error phase1 negociation failed due to time up 45.13.94.170[500]<=>77.204.176.9[1525]1ddabfc337ad5334:27ab8ad322357ad2
At the end of the post, my full configuration.
But before, i give some supposed problem to be fixed if possible.
I have already check :
-NAT table => no action = dst-nat
-routing BGP (network, peer) and routing filter
Maybe the problem come from /ip firewall mangle but i don't know what do exactly this rules :
Code: Select all
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=vpn passthrough=yes src-address=10.0.19.0/24
add action=change-mss chain=forward new-mss=1410 out-interface=l2tp1 passthrough=no protocol=tcp tcp-flags=syn tcp-mss=1411-65535
add action=change-mss chain=forward in-interface=l2tp1 new-mss=1410 passthrough=no protocol=tcp tcp-flags=syn tcp-mss=1411-65535
Code: Select all
/ip settings
set accept-redirects=yes accept-source-route=yes
Code: Select all
set default disabled=yes
add as=65103 client-to-client-reflection=no name=AS65015_V4 redistribute-other-bgp=yes router-id=10.0.19.1 routing-table=vpn
MY FULL CONFIGURATION
Code: Select all
# oct/29/2020 20:24:38 by RouterOS 6.46.4
# software id = 6HR7-IG6H
# model = RBD52G-5HacD2HnD
# serial number = B4A00XXXXXXXXX
add name=Loopback0
add name=bridge1
/interface wireless
set [ find default-name=wlan2 ] country=france disabled=no mode=ap-bridge \
ssid=home_jo_5Ghz
add name=WAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
supplicant-identity=MikroTik
add authentication-types=wpa-psk,wpa2-psk eap-methods="" \
management-protection=allowed mode=dynamic-keys name=profile1 \
supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country=france disabled=no \
frequency=2437 mode=ap-bridge security-profile=profile1 ssid=home_jo \
wps-mode=disabled
/ip hotspot profile
/ip ipsec peer
# This entry is unreachable
add name=l2tpserver passive=yes
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
add name=LAN ranges=10.0.19.10-10.0.19.200
add address-pool=LAN disabled=no interface=bridge1 name=LAN
/ppp profile
add local-address=10.0.19.1 name=ipsec_vpn
/interface l2tp-client
add allow=mschap2 allow-fast-path=yes connect-to=80.57.167.30 disabled=no \
name=l2tp0 profile=default user=jo_cust
add allow=mschap2 allow-fast-path=yes connect-to=80.57.167.31 disabled=no \
name=l2tp1 profile=default user=jo_cust
/routing bgp instance
add as=65103 client-to-client-reflection=no name=AS65015_V4 \
add as=65103 client-to-client-reflection=no name=AS65015_V6 \
redistribute-other-bgp=yes router-id=10.1.0.212
add bridge=bridge1 interface=wlan2
add bridge=bridge1 interface=wlan1
/ip settings
/interface l2tp-server server
set default-profile=ipsec_vpn enabled=yes use-ipsec=required
add interface=l2tp0 list=WAN
add interface=l2tp1 list=WAN
add address=10.0.19.1/24 interface=bridge1 network=10.0.19.0
add address=45.13.94.170 interface=Loopback0 network=45.13.94.170
/ip dhcp-client
add disabled=no interface=ether1 use-peer-dns=no
/ip dhcp-server lease
add address=10.0.29.200 mac-address=70:85:C2:B5:A5:74 server=LAN
add address=10.0.19.11 mac-address=E0:CB:4E:06:4A:F5 server=LAN
add address=10.0.19.0/24 dns-server="80.67.169.12,80.67.169.40,37.187.16.17,52\
.174.55.168,85.159.213.210,193.183.98.154" gateway=10.0.19.1 netmask=24
set servers="80.67.169.12,80.67.169.40,37.187.16.17,52.174.55.168,85.159.213.2\
10,193.183.98.154"
add action=accept chain=input comment="Allow L2PT / IPSec VPN access" \
disabled=yes dst-port=500,1701,4500 protocol=udp
add action=accept chain=input disabled=no protocol=ipsec-esp
add action=accept chain=input disabled=no protocol=ipsec-ah
add action=accept chain=input dst-port=8291 protocol=tcp
add action=accept chain=forward
add action=accept chain=output
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=vpn passthrough=yes \
add action=change-mss chain=forward new-mss=1410 out-interface=l2tp1 \
add action=change-mss chain=forward in-interface=l2tp1 new-mss=1410 \
add action=src-nat chain=srcnat comment="L2TP MILKYWAN" out-interface=l2tp0 \
src-address=10.0.19.0/24 to-addresses=45.13.94.170
add action=src-nat chain=srcnat comment="L2TP MILKYWAN" out-interface=l2tp1 \
add action=dst-nat chain=dstnat comment="HTTPS - server" dst-address=\
45.13.94.170 dst-port=443 protocol=tcp to-addresses=10.0.29.200 \
to-ports=443
add action=dst-nat chain=dstnat comment="HTTP - server" dst-address=\
45.13.94.170 dst-port=80 protocol=tcp to-addresses=10.0.29.200 to-ports=\
80
add action=dst-nat chain=dstnat comment="MAIL_MTP - server" dst-address=\
45.13.94.170 dst-port=25 protocol=tcp to-addresses=10.0.29.200 to-ports=\
25
add action=dst-nat chain=dstnat comment="MAIL_SMTPS - server" dst-address=\
45.13.94.170 dst-port=465 protocol=tcp to-addresses=10.0.29.200 \
to-ports=465
add action=dst-nat chain=dstnat comment="MAIL_SMTP - server" dst-address=\
45.13.94.170 dst-port=587 protocol=tcp to-addresses=10.0.29.200 \
to-ports=587
add action=dst-nat chain=dstnat comment="SSH - server" dst-address=\
45.13.94.170 dst-port=4447 protocol=tcp to-addresses=10.0.29.200 \
to-ports=4447
add action=dst-nat chain=dstnat comment="SSH - server" disabled=yes \
dst-address=45.13.94.170 dst-port=4500 protocol=tcp to-addresses=\
10.0.19.11 to-ports=4500
out-interface-list=WAN
add action=src-nat chain=srcnat out-interface-list=WAN to-addresses=\
45.13.94.170
add action=masquerade chain=srcnat comment=HAIRPIN-NAT dst-address=\
10.0.19.0/24 src-address=10.0.19.0/24
/ip ipsec identity
add generate-policy=port-override peer=l2tpserver
/ip ipsec policy
set 0 dst-address=0.0.0.0/0 src-address=0.0.0.0/0
/ip route rule
add action=lookup-only-in-table dst-address=10.0.19.0/24 table=main
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip smb shares
set [ find default=yes ] directory=/pub
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/ipv6 address
add address=XXXXXXXXXXXXXXXXXX interface=bridge1
add address=XXXXXXXXXXXXXXXXXXXX advertise=no interface=l2tp0
add address=XXXXXXXXXXXXXXXXXXXX advertise=no interface=l2tp1
/ppp secret
add local-address=10.0.19.1 name=jo profile=ipsec_vpn remote-address=\
10.0.29.210 service=l2tp
/routing bgp network
add network=10.0.19.0/24 synchronize=no
add network=XXXXXXXXXXXXXXXXXXXX synchronize=no
add network=45.13.94.170/32 synchronize=no
/routing bgp peer
add in-filter=transit-in-57159-brs-v4 instance=AS65103_V4 name=\
"Transit: MilkyWan brs [IPv4]" out-filter=transit-out-57159-brs-v4 \
remote-address=10.1.0.123 remote-as=65006 ttl=default
add address-families=ipv6 in-filter=transit-in-57159-brs-v6 instance=\
AS65103_V6 name="Transit: MilkyWan BRS [IPv6]" out-filter=\
transit-out-57159-brs-v6 remote-address=2a0b:cbc0:1::111 remote-as=65006 \
ttl=default
add address-families=ipv6 in-filter=transit-in-57159-vnx-v6 instance=\
AS65103_V6 name="Transit: MilkyWan VNX (Backup) [IPv6]" out-filter=\
transit-out-57159-vnx-v6 remote-address=2a0b:cbc0:1::115 remote-as=65002 \
ttl=default
add in-filter=transit-in-57159-vnx-v4 instance=AS65103_V4 name=\
"Transit: MilkyWan vnx [IPv4]" out-filter=transit-out-57159-vnx-v4 \
remote-address=10.1.0.127 remote-as=65002 ttl=default
/routing filter
add action=accept chain=transit-in-57159-vnx-v4 set-bgp-prepend=2
add chain=---
add action=accept chain=transit-out-57159-vnx-v4 prefix=10.0.19.0/24 \
set-bgp-prepend=2
add action=accept chain=transit-out-57159-vnx-v4 prefix=45.13.94.170 \
set-bgp-prepend=2
add action=discard chain=transit-out-57159-vnx-v4
add chain=---
add action=accept chain=transit-in-57159-vnx-v6 set-bgp-prepend=2
add chain=---
add action=accept chain=transit-out-57159-vnx-v6 prefix=2a0b:cbc0:1116::/48 \
set-bgp-prepend=2
add action=discard chain=transit-out-57159-vnx-v6
add chain=---
add chain=---
add chain=---
add action=accept chain=transit-in-57159-brs-v4
add chain=---
add action=accept chain=transit-out-57159-brs-v4 prefix=10.0.19.0/24
add action=accept chain=transit-out-57159-brs-v4 prefix=45.13.94.170
add action=discard chain=transit-out-57159-brs-v4
add chain=---
add action=accept chain=transit-in-57159-brs-v6
add chain=---
add action=accept chain=transit-out-57159-brs-v6 prefix=XXXXXXXXXXXXXXXXXX
add action=discard chain=transit-out-57159-brs-v6
/system clock
set time-zone-name=Europe/Paris
/system logging
add topics=ipsec,!packet
add topics=l2tp,!packet
/system routerboard settings
set auto-upgrade=yes boot-protocol=dhcp silent-boot=yes
