MarcTomlinson
wAP ac with R11e-LTE receives exactly 1 packet then no more rx.
Fri Nov 20, 2020 1:36 am
Hi. I've got this really weird problem with my wAP ac. The problem occurred with default config so I've stripped down all the config to bare minimum to test the problem. I have a gaffgaff sim - and everything checks out there end. The lte modem connects, registers and is assigned its ip, dns, etc, etc - all looks good - but there's no internet connectivity. Tried the usual ping 8.8.8.8 and found that immediately after the lte interface is reset (disabled / enabled) I receive exactly 1 packet ( the icmp reply ) and then nothing else. Here's the ping results >
 SEQ HOST                                     SIZE TTL TIME  STATUS
  240                                                         no route to host
  241                                                         no route to host
  242                                                         no route to host
  243                                                         no route to host
  244                                                         no route to host
  245 8.8.8.8                                    56 113 50ms
  246 8.8.8.8                                                 timeout
  247 8.8.8.8                                                 timeout
  248 8.8.8.8                                                 timeout
  249 8.8.8.8                                                 timeout
As you'd expect - 'no route to host' whilst lte is disabled ( there's no default route as its assigned via dhcp in connect), then the 1 ping, then timeout.
IP route once connected looks ok :
 0 ADS  0.0.0.0/0                          lte1                      2
 1 ADC  10.145.248.43/32   10.145.248.43   lte1                      0
 2 ADC  192.168.99.0/24    192.168.99.4    LanBridge                 0
Modem details :
/interface lte info lte1 once
pin-status: ok
registration-status: registered
functionality: full
manufacturer: "MikroTik"
model: "R11e-LTE"
revision: "MikroTik_CP_2.160.000_v010"
current-operator: O2 - UK
lac: 35056
access-technology: Evolved 3G (LTE)
session-uptime: 2h2m42s
earfcn: 6400 (band 20, bandwidth 10Mhz)
Here's the config i'm running :
# jan/02/1970 00:21:17 by RouterOS 6.47.7
# software id = 6BGL-34M9
# model = RBwAPGR-5HacD2HnD
# serial number = AAA70A0357DE
add name=LanBridge
/interface lte
set [ find ] name=lte1
/interface wireless
set [ find default-name=wlan1 ] disabled=no ssid=MikroTik
set [ find default-name=wlan2 ] ssid=MikroTik
add name=LAN
add name=WAN
/interface lte apn
set [ find default=yes ] apn=giffgaff.com authentication=chap name=giffgaff user=giffgaff
add bridge=LanBridge interface=wlan1
add bridge=LanBridge interface=wlan2
add bridge=LanBridge interface=ether1
add bridge=LanBridge interface=ether2
add interface=LanBridge list=LAN
add interface=lte1 list=WAN
add address=192.168.99.4/24 interface=LanBridge network=192.168.99.0
set allow-remote-requests=yes
/system logging
add topics=lte,!raw
Any help would be much appreciated.
Marc
Users browsing this forum: Bing [Bot], cipis, hannz, joris77 and 98 guests
