MUM Europe 2020
Peace
3.0beta10 bug
Fri Jul 06, 2007 9:21 am
After I upgrade my router from 2.9.44 to 3.0beta10:
Tourch not working - say "not enough permissions (9)" I have full permissions
And some scripts also no working say what there are some syntax errors, before upgrade all scripts was working fine.
mrz
Re: 3.0beta10 bug
Fri Jul 06, 2007 9:49 am
there are new variable system in v3.0, most of old scripts won't work.
janisk
Re: 3.0beta10 bug
Fri Jul 06, 2007 10:38 am
there is new option in /user group
called sniff, add this to your group and relogin into router, that way you will have correct rights to use torch and other tools
this occurs if you upgrade from beta to newest beta10, id upgrade from 2.9.xx everything should be fine.
Peace
Re: 3.0beta10 bug
Fri Jul 06, 2007 10:42 am
Thnks, janisk!
Before I see You post I did it and Torch started working :)
kvan64
Re: 3.0beta10 bug
Sun Jul 08, 2007 6:06 pm
Is there a newer/second version of beta10?
Peace
Re: 3.0beta10 bug
Tue Jul 17, 2007 9:20 am
My APC UPS stopped to work with beta10
What where can be for problems?
Users browsing this forum: dad2312, Google [Bot] and 102 guests
