MUM Europe 2020
awacenter
PPTP + RADIUS: Framed-Route ignored
Fri Jul 06, 2007 12:11 pm
I achieved that my MT PPTP server autheticates a PPTP client via RADIUS.
radreply table for the user 22110.
"22110";Framed-Protocol";":=";"PPP"
"22110";"Service-Type";":=";"Framed-User"
"22110";"admin";"Framed-Compression";":=";"Van-Jacobson-TCP-IP"
"22110";"Framed-IP-Address";":=";"10.200.200.2"
"22110";"Framed-IP-Netmask";":=";"255.255.0.0"
"22110";"Tunnel-Type";":=";"13"
"22110";"Tunnel-Medium-Type";":=";"6"
"22110";"Tunnel-Private-Group-Id";":=";"4"
"22110";"Framed-Route";":=";"10.200.0.3 10.200.0.10 1"
PPTP server asigns the IP 10.200.0.10 as Remote Peer address. It works fine.
However, I want to create a new route dinamically:
10.200.0.3 10.200.0.10 1 pptp-out1
but I can not do it because Framed-Route attribute is ignored by the MT. Is it true??
if it is supported, could you give me an example?
Thanks.
tneumann
Re: PPTP + RADIUS: Framed-Route ignored
Sat Jul 07, 2007 1:40 am
The Framed-Route should use the Framed-IP-Address that is assigned to the client as the next hop.
--Tom
awacenter
Mon Jul 09, 2007 1:45 pm
But, what I wnat to know is if Framed-Route is supported by mikrotik. Yes or no??
If it is yes, could you give me an example? Thanks
tneumann
Mon Jul 09, 2007 8:06 pm
Yes, of course it's supported.
See the RouterOS manual at http://www.mikrotik.com/testdocs/ros/2. ... radius.php
For the correct format of the Framed-Route attribute see http://www.ietf.org/rfc/rfc2865.txt (Chapter 5.22)
--Tom
awacenter
Tue Jul 10, 2007 11:03 am
--Tom
I try lot of configurations for this attribute:
"22110";"Framed-Route";":=";"10.200.0.3/32 10.200.0.10 1"
"22110";"Framed-Route";":=";"10.200.0.3 /32 10.200.0.10 1"
and it do not work. I followed http://www.ietf.org/rfc/rfc2865.txt . could you verify the syntax of one of this three rules is correct?
Thanks.
tneumann
Wed Jul 11, 2007 8:59 am
Why do you specify 10.200.0.10 as the next hop? You're assigning 10.200.200.2 to the client (with the Framed-IP-Address attribute), so you have to use that client IP address as the next hop if you want to add a route towards that client.
Try this:
"22110";"Framed-Route";":=";"10.200.0.3/32 10.200.200.2 1"
--Tom
Users browsing this forum: MSN [Bot] and 111 guests
