MUM Europe 2020
conchalnet
Limiting the packets per second - dst-limit
Thu Jul 12, 2007 8:35 pm
Hi all,
I want to limit the packets per second on my APs for each customer. I saw in the Mikrotik manual that this can be done with dst-limit in the filter rule, but I dindn't able to put this in pratic.
How can I make this? Is it possible?
Regards,
Fabrício F. Kammer
Conchalnet
savagedavid
Trainer
Trainer
Re: Limiting the packets per second - dst-limit
Thu Jul 12, 2007 10:25 pm
The dst-limit is an "accept" rule - so this rule will match if limit is at or below the specified amount. You would need a drop rule of some sort after the dst-limit rule to limit the sessions
conchalnet
Thu Jul 12, 2007 10:55 pm
Hi savagedavid,
Thanks for your answer, but I don't understand it. Can you give an example of how I have to do to limit the pps of my customers?
Regards,
Fabrício F. Kammer
Conchalnet
Users browsing this forum: anav, Google [Bot], MSN [Bot], schrotn and 118 guests
